LSUROCKS
Member since March 2011
Post by LSUROCKS on Apr 4, 2011 0:36:18 GMT -5
what would I need to get to put a 6" diamond blade on the left side of the shaft if I have it 1/4"-20 center drilled?
Post by jakesrocks on Apr 4, 2011 9:13:33 GMT -5
Don't ! That 1/4 - 20 screw isn't big enough to handle the blade.
LSUROCKS
Post by LSUROCKS on Apr 4, 2011 9:47:14 GMT -5
Well that end is going to be threaded so all I need to do is find some sort of 3/4" threaded hub or maybe just put the blade directly on the shaft. Thats pretty much the last thing I need to figure out I should have everything and the machine built in the next week...CROSSES FINGERS
Post by jakesrocks on Apr 4, 2011 19:29:53 GMT -5
If there's enough thread showing on the left end of your shaft, get a blade with 3/4" center hole, 2 flange washers and another left hand thread nut. Put the blade directly on the shaft. It will be stronger and safer than using some sort of adapter.
zarguy
Member since December 2005
Post by zarguy on Apr 5, 2011 2:28:30 GMT -5
LSUROCKS
Post by LSUROCKS on Apr 5, 2011 8:11:14 GMT -5
I read it several times zar and its definatly helped me out alot.
Preston
LSUROCKS
Post by LSUROCKS on Apr 5, 2011 8:44:03 GMT -5
Well I decided to use 13"x9" cake pans for the pans and acually looks pretty nice and I have a sheet of aluminum that I am going to use for the hood. I havent figured out how to build the frame yet without being able to weld but I am working on it. I have a 1/2"x72" square tubing I want to use any ideas how I can acually put it together? Only option I can think of is to use some angle iron to bolt everything together but with the vibration I would expect nuts and bolts to wiggle loose. The base is complete I used 3/4" plywood used a waterproofing staine then put a few coats of spary on bedliner LOL That thing is so waterproof its crazy. The cake pans will be a perfect fit for the setup I have and they are fairly thick and sturdy. I just got me a used 1725 rpm 1/2hp Leeson farm duty motor for $60+shipping already has the pulley and power cord. I will get some pics of the machine when I am done for all to see. Now if Kev would get back with me and let me know if he will make the shaft I will be soooooo happy...LMAO Attachments:
Post by Jack, lapidaryrough on Apr 5, 2011 10:27:31 GMT -5
fine looking Motor, i use the same in 1-Hp, on my 24" Fran-tom saw.
Smart thinking using the cake pans.
The 1/2 pans used in industrial i was considering using one for a trim saw pan.
Sounds like your cabbing unit, Well be Millwright Grade.
Looking forward to the muddy pan look.
Jack
LSUROCKS
Post by LSUROCKS on Apr 5, 2011 10:52:52 GMT -5
Acually the cake pans have 2" sides so pleanty deep enough. I just hope everything comes in soon cuz I wanna make some cabs...LOL
Post by cpdad on Apr 5, 2011 12:39:14 GMT -5
i have the shaft complete except for the 1/4" left hand threads.....seems someone liked my left handed tap more than i did....a new one will be here in the morning.
go ahead and pm me your address....i should be able to get it in the mail tomm afternoon or thursday... and i picked up the right and left hand nuts for you also....kev.
LSUROCKS
Post by LSUROCKS on Apr 5, 2011 12:57:35 GMT -5
Kev dont worry about the left hand 1/4" threads I wont be able to use them for the blade it will be too small
Post by cpdad on Apr 5, 2011 18:20:20 GMT -5
okay then...no 1/4" left hand...there is a hole there for it if you wanna tap it later on....its boxed up...and will be on the way sometime tommorow...nuts included....will give total when shipping is known....i sure hope your machine works out well...if you need anything else at all please let me know ;D...kev.
LSUROCKS
Post by LSUROCKS on Apr 6, 2011 8:44:59 GMT -5
Thank you so much kev you the bestest. :-)
Preston
LSUROCKS
Post by LSUROCKS on Apr 6, 2011 9:01:57 GMT -5
OK now that I have everything ordered or incomming exept the polishing disc I have a question. www.gravescompany.com/beltsand.htmThey have on the site a quick disc which has the 1/4"-20 base but I am trying to figure out how its gonna work. They have leather and felt discs I am guessing they attach to the quick disc or do they have thier own base with 1/4"20 It doesnt say on the website so thought one of you guys may know.
Post by jakesrocks on Apr 6, 2011 9:44:43 GMT -5
Since you're building on a limited budget, I'd suggest you look at the disks and pads in the Kingsley North catalog. When you buy directly from a manufacturer like Graves, you usually end up paying more. You'd be best to have Different disks for each polish you plan to use, and store them in zip lock bags when not in use.
LSUROCKS
Post by LSUROCKS on Apr 6, 2011 10:03:09 GMT -5
I checked both sites out and graves is acually cheaper.
drjo
Honduran Opal & DIY Nut
Post by drjo on Apr 7, 2011 7:59:38 GMT -5
"Used as a backing disc for various polishing and sanding pads"
You spin it on the shaft and use 3M feathering adhesive to attach different grinding/polishing discs, which will peel off for changing.
Dr Joe
Post by johnjsgems on Apr 7, 2011 13:10:22 GMT -5
You can buy the Quick Discs (also called Spin Discs) with either just the foam or with leather, canvas or felt. If you buy the plain ones buy 3M Feathering Disc Adhesive to glue on the discs. Leather is most economical and performs better than canvas for most polish. Canvas works well for diamond compound. Felt works very well for many polish compounds but costs more.
LSUROCKS
Post by LSUROCKS on Apr 7, 2011 15:22:00 GMT -5
Well I am hoping to have everything in and can finish making my machine over the weekend. I guess I will be able to shape the stones but I will have to wait till next week to get the polishing equipment and material so no polishing for a little while...:-(
Post by cpdad on Apr 7, 2011 21:01:53 GMT -5
shipping was $9.20....so the total for the shaft is $49.20....just wanted to post in the thread....just to make sure all seen it was on the up and up.
sending PM with paypal addy....kev.
