Post by Jack ( Yorkshire) on May 28, 2011 4:46:01 GMT -5
Hi All As promised the testing out of Zinc Oxide 1 - Before 2 - After 3 - Popy Jasper ? from Tom 4 - Montrose Agate 5 - Carnelian 6 - Yellow Quartze, Black Flint, Chaldony & Amy ' 7 - Geode slice 8 - Chaldoney 9 - Amy and Agate (and a Non polished Shap Granite ?) 10 - Chaldony [glow=red,2,300] Polished using the Conrock Method [/glow] I found this Polish as good as any I have used so far , I also found it washed out of the cracks indentations Geode slice inside a lot better than TO or CO I used up a batch of prepared rocks ( stage one ) and had to add some with cracks and indentations , I also added a few Pre cuts so it gave this batch a good challenge , I think the final photo #10 of the bubbly surface on the Chaldony shows the finish off the best Your coments much appreciated Jack Yorkshire uk
unclestu
WINNER OF THE FIRST RTH KILLER CAB CONTEST UNCLESTU'S AGUA NUEVA AGATE
Member since April 2011
Post by unclestu on May 28, 2011 5:28:17 GMT -5
Jack the result that you have achieved was outstanding. Thanks for spending the time to run the test. Stu
Post by johnjsgems on May 28, 2011 8:19:22 GMT -5
Looks like it works well. Any safety concerns? I remember in the distant past hearing not to build smokers out of galvanized containers because of the zinc coating. Not sure how readily available it is in USA either.
Post by Sabre52 on May 28, 2011 8:41:51 GMT -5
Not totally sure on this but I believe the main toxicity from zinc oxide is inhalation of zinc oxide in gaseous form which is probably why they don't want you to use it for smokers. Don't think solid form is very toxic. Great results on the tumble. I wonder why it's not available here as a polish. May be an expense thing. Was it inexpensive there in the UK? Kind of hard to beat the cheap cost of good AO here in the US......Mel
Post by johnjsgems on May 28, 2011 8:58:22 GMT -5
He said in an original post he was testing it for a company from Africa and AO not readily available in UK. Be interesting if it was available for another use here and could be bought without a rock hobby mark up.
unclesoska
Member since February 2011
Post by unclesoska on May 28, 2011 9:31:15 GMT -5
I could very easily be wrong about this, but I believe the active ingredient in Preparation H is zinc oxide...
Post by Toad on May 28, 2011 9:54:54 GMT -5
Wow! Looks like that stuff does the trick.
Post by Toad on May 28, 2011 9:57:37 GMT -5
Isn't zinc oxide what the lifeguards use on their noses? If so, don't think it is too toxic...
Post by paulshiroma on May 28, 2011 10:40:32 GMT -5
That was impressive, Jack. Thanks for posting the results. Now we just have to figure out how to get some in the States, assuming the price isn't outrageous. To Mel's point, the price point of AO makes it hard to beat.
Great photos, by the way.
Post by Fossilman on May 28, 2011 11:10:54 GMT -5
GREAT looking stones,and thanks for letting us know of this method.......
Post by tntmom on May 28, 2011 12:59:56 GMT -5
That zinc worked great. Nice batch and shine Jack!!
~Krystee
Post by Jack ( Yorkshire) on May 28, 2011 13:54:58 GMT -5
carloscinco
Member since July 2008
Post by carloscinco on May 28, 2011 19:17:12 GMT -5
I looked up the hardness of Zinc Oxide which is listed at 4.5 versus AO which is listed as 9. Does this mean it takes longer to produce the same results as AO?
Post by connrock on May 29, 2011 7:23:50 GMT -5
Outstanding results Jack!
Your photos are #1 as well!
With results like that it's a shame you didn't enter the rock tumbling competition this year!!!
connrock
Post by Jack ( Yorkshire) on May 30, 2011 0:46:19 GMT -5
Hi Carlo I just gave them the same time as other times in fact 3 1/2 hours less I was antious to see the results and took them off at 5 -30 am Thanks Tom mabe next year DV I will have a go at the rock polishing contest see how you do this year? This polish certainly worked well the photos dont realy show the high gloss on all the rocks We will see how the next batch turns out with a fair quanity of pre forms and cabs in it in 11 days time Jack Yorkshire uk
Post by tanyafrench on May 30, 2011 7:38:39 GMT -5
Jack those are awesome. I will have to watch for the Zinc oxide coming out as a polish in the USA.
Tanya
snuffy
Member since May 2009
Post by snuffy on May 30, 2011 14:38:32 GMT -5
I was wondering,sometimes I do that too much. I googled zinc oxide and there seems to be numerous sellers of zinc oxide powder,for different uses. Would the recipe for the ZO polishing product be any different than what is out there for sale?
snuffy
rallyrocks
Member since November 2005
Post by rallyrocks on May 30, 2011 18:48:02 GMT -5
I could very easily be wrong about this, but I believe the active ingredient in Preparation H is zinc oxide... You are in fact pretty wrong about that- the ointment anyway. The active ingredients in Preparation H are mineral oil, petroleum, Phenylephrine HCL and shark oil. ZnO is not even an inactive ingredient, it is however used in those solid white sunscreens that nobody uses anymore. If it is used in the creme formulation it would be an inactive ingredient used for coloring.
Post by beefjello on May 30, 2011 21:57:58 GMT -5
Looks like zinc oxide makes for a mighty fine polish! Really nice shine there Jack!
Post by Jack ( Yorkshire) on Jun 1, 2011 1:16:59 GMT -5
Hi Tanya Should be comming onto the USA market soon here is a link www.ukge.com/usa/HiSnuffy I used the same recepie as I did for the other polishes so I had a reference point, Hi beefjello, Thanks yes it didnt do to bad Im doing another batch at present to check a few things this particular batch Available soon in USA at www.ukge.com/usa/Jack Yorkshire uk
