emyhro4048
Member since March 2007
Post by emyhro4048 on Feb 22, 2012 6:34:21 GMT -5
Hi everyone, I picked up some Girasol Opal [spelling?] some time ago from the Rock Shed I believe and need to know something about it and how to tumble it. I tried once and the results weren't that great. Thank's for the help. Ed M.
Post by helens on Feb 22, 2012 18:40:24 GMT -5
I don't think Girasol opals are real opals... the descriptions I've read are that it's 'milky quartz'. Quartz has a 7 hardness... most opals are 5.5-6 hardness. They are very different. I've done real opals, but no Girasol, but I would think you'd follow directions for regular tumbling, which are posted all over the forum. Just make sure that because these are your focus, that they are the hardest stones in your whole batch, and you should be ok:)
Post by susand24224 on Feb 22, 2012 19:33:18 GMT -5
I've tumbled them, and there is nothing unusual. I've put them in with other crystalline quartzes, such as amethyst, rose quartz, etc. I think I added some ceramics in the later stages to cushion, though.
Susan
emyhro4048
Post by emyhro4048 on Feb 22, 2012 22:20:34 GMT -5
Thank you for your responses.
Ed M.
Post by helens on Feb 24, 2012 1:53:28 GMT -5
Ed, if this helps, these are the opals that just came out of my tumbler today. Australian Opals on left, the different colored ones on right are Ethiopian hydrophane and Turkey opals that did not finish polishing the last tumble run (the Aussie opals came from Christopher1234)- note: all below opals are damp, picture shot in filtered sunlight: The lumpy pitted ones were not put in until the final polish stage. I did not want them fully polished, I wanted them a bit shiny so I could see where the fire was, since I plan to save them for carving. Here's what fully polished opals in a tumbler look like (some were preshaped, others were not, some started out cracked, but all of them shine:)). Note, all below opals are dry, picture shot under LED lighting (the fires do not show up under normal lighting on these):
emyhro4048
Post by emyhro4048 on Feb 24, 2012 22:36:08 GMT -5
Wow Helen, those are amazing and such a beautiful shine!
Ed M.
Post by geoff on Feb 25, 2012 2:26:12 GMT -5
I've tumbled it in the past. I ran it with agate and quartz in my lot o and it turned out great. It can have flashes of green in it, but it's like the irredescence in the hairline cracks in quartz, not true fire.
Post by helens on Feb 25, 2012 4:42:04 GMT -5
Geoff, you are talking about Girasol or opals? You can't run real opals with agates, only the girasol ... my first batch was ethopian welo gem quality (I know, that was dumb:P), and I ran them with fire agates in the first grit stage in a Lot-O. Yikes! I lost 40% volume in a day. I took the agates out very quickly!! After that, I still lost some volume, but not nearly so much. The batch pictured above are Australian opals, mostly potch matrix, but some fire, and also some ethiopian welo. The attachment is what I ended up with from my first batch, and I had about double the size in the jar when I started. But some of that was clay and matrix too, so it wasn't as bad as it sounds. Still, they were gem opals, so it was still a loss. I wasn't sure if you were talking about girasol opals or opals, I'm not sure why they call anything greater than 5.5 hardness opals, but they do, and for tumbling, that can mess people up. You can't put agates in with gem opals. Attachments:
Post by geoff on Feb 25, 2012 12:20:19 GMT -5
Sorry, girasols. The shop I bought them at in kent, wa had them labeled girasol quartz. Probably to prevent confusion.
Post by geoff on Feb 25, 2012 12:24:30 GMT -5
The only non-metaphysical info I could find quickly is this: Girasols, more commonly called fire opals, are transparent to translucent opals with warm body colors of yellow, orange, orange-yellow or red. They do not usually show any play of color, although occasionally a stone will exhibit bright green flashes.
Post by susand24224 on Feb 25, 2012 15:16:59 GMT -5
There are both girasol opals and girasol quartz. The stuff the Rockshed sells as "girasol opal" is really girasol quartz. (said to save the original poster from complete confusion)
Post by helens on Feb 25, 2012 15:54:04 GMT -5
Noo.... fire opals are not girasols. Fire opals are from Mexico with a 5.5 hardness. I'm pretty sure 'girasol' anything is 7 hardness.
That confusion could cost someone a LOT of money if they were tumbling. If you throw even fire opals in with agates, you are going to lose a lot of fire opals. If you aren't paying attention to the loss, by the end of the first week, every single fire opal you put in might be powderized, leaving you with no opals at all.
Also, you CANNOT put opals in a rotary tumbler. While I haven't tried this, everything I've read says you cannot, and I'd imagine at some point the advice came from someone who destroyed their opals.
While opals are not the most expensive gemstones by a mile, some can still be considered precious gems, and the top graded could command as much as $75 per carat, which is 1/5 of a gram, or $375 per gram, or $375,000 per kilo (2.2 lbs).
Of course, no one in their right mind tumbles half a million dollars worth of opals without knowing what they are doing, but you do have to be careful saying it in case someone thinks of it as a fast easy way of cleaning and polishing (like me).
I DID throw 1/2 a pound of precious gem opals into my tumbler as a first batch, all with real fire, and some with top grade fire, because I realized HOW LONG it would take to clean and polish them one at a time.
Note, MY opals weren't the $75 per carat variety, but they are definitely of the $1-$5 per carat variety. Even at $1, 1/2 a pound is $1240, so yes, I threw over a thousand dollars into my tumbler first batch and took a $600 cash loss for trying it. And try to make light of it because I am not going to get either the opals or the money back. Of course I would rather buy a saw or grinder with the money than let my tumbler eat it.
I post this because I think anyone thinking of tumbling opals needs to read it, and do a whole lot of research before taking the kind of loss I did. DO NOT TUMBLE OPALS WITH AGATES.
I can't fathom why anyone started calling quartzes opals. That just makes no sense at all, and in a situation like tumbling, can lead to their destruction if you just toss them in with harder rocks.
Post by helens on Feb 25, 2012 16:16:07 GMT -5
After thinking about it a bit, I think the best idea is if you tumble ANYTHING called 'opals', you should err on the side of caution and tumble them as a dedicated batch alone (with ceramic or glass filler material).
I posted my experience because there's no reason for anyone else to suffer the loss I did, but I learned a lot from it and I knew the risk. If it helps prevent others from making the same mistakes, it may make me feel better:).
I also need to point out that one reason I didn't lose more of the opals was the outstanding advice from the various threads on this tumbling forum from the knowledgeable people here.
As you can see, I had almost no loss from the 2nd batch, because I learned so much from the first batch. But in every case, it was what I learned here that saved me a lot more expensive trial and error.
Just because you 'can' do something (maybe), doesn't mean you should. Anything called 'opal' means it's going to be a bit pricier or perhaps a bit nicer than others of its type. It should probably be dealt with separately.
There can be misinformation on the web (like the site Geoff found, calling yellow, orange and red fire opals 'girasol'!), just better to err on the side of careful, especially if you are worried about the stones.
So, if it says 'opal', tumble it by itself, you can't lose anything that way:).
chassroc
Post by chassroc on Mar 6, 2012 9:16:30 GMT -5
Helen, One of the ladies in the Arts and Crafts Society asked me about some Opals last night. She does not have a tumbler, (nor a grinder or saw) and she asked if I could tumble them for her. Hmmm? She got them from family 15 or twenty years ago and got excited after I did a saw and grinding exhibition for the members. Hers are Australian, but only a few (20%) have fire and only about 4 or 5 appear to have gem quality fire of varying degree. Some have thin veins that would likely be better used for doublets or triplets, a couple need to be explored further. I told her to wait until the weather got above 60 and I would spend a saturday with her and her opals. I was going to concentrate on the ones with fire and try to cut a few nice cabs from the ones with the most potential and one boulder opal (about one by 2.5inches) that has some potential.
As for tumbling. I thought I might do a batch with all the common opal. Did you use coarse grit on any of your opals? Is it better to start with medium(220) grit?. The thin or not quite enough (or is that semi) precious stones - do you think the potch will tumble grind off more easily than the precious layers?
Charlie
Post by helens on Mar 6, 2012 22:40:37 GMT -5
Hi Charlie:). First, I'd pull out the 'best' pieces that you may want to cab later, or pieces with obvious cracks. Those cracked ones ARE going to split, and if the opals have any value, it might be better to opticon them and then cut, rather than let them just break apart into sand.
My main goal in tumbling them was to get a shine on, to see if some stones with no apparent fire could be coaxed into showing some, and to get rid of excess dirt and matrix. Tumbling won't help much with pitting, other than to make it worse.
I started the opals in 500 grit, in a Vibe tumbler, I don't have a rotary, and I don't think I'd try opals in a rotary anyway, based on what others have said.
I was worried that the 220 grit would take too much off the opals... some of the ones I tumbled were SMALL (under 2 carats in some cases).
Starting with 500 grit, I still watched them... my goal wasn't to shape the opals, it was to get a polish, even if they were rough with pitting. If they have fire, someday you may want to cab them, and removing a lot of stone means less to work with later. On the not cabbables, I thought I might want to carve them later... so again, the shape was no big deal.
That said, those that you will make doublets or triplets from, I wouldn't tumble, because you can't predict WHERE the material is going to rub off of, and sometimes, it's the best parts. That said, I did not notice potch coming off any differently than the firey parts. I would say that it removes at the same rate. It's just more noticeable and painful when it's the fire part vanishing.
Oh, I would NOT put ANY boulder opal in a tumbler unless you are prepared for all that matrix to disappear. The matrix is often very soft, you'd end up with holey completely unuseable boulder opals. For boulder opals, I'd slice them, then polish as is, the tumbler would undercut them into a big mess.
As soon as I saw that the dirt and matrix was mostly gone, I immediately washed the whole batch and put into 1000. That made me feel a little safer about the abrasion.
I used about 1/2 a tsp of borax AND a 1/2 tsp of Cascade dishwashing detergent in all my batches. I find that that makes rinsing very easy, and if it doesn't affect opal fire, I can't see why it would affect anything else. I haven't seen anyone else recommend doing that, so do it with a grain of salt, or use ivory soap flakes (I didn't have any).
At the 1000, I don't bother rinsing again, I added 1/2 a tsp of tripoli the next day, and then let it run til the rocks looked almost polished (about 2 more days). Then I added a spoonful of polish. If you still had any mud or matrix when you started the 1000, you may want to wash the batch at least once more before going for the polish.
That's it. The only real caveat would be that you use NO other stones in there with the opals. The only filler (and best filler), should be ceramic media OR glass. My first batch, I didn't have any ceramic media yet, and I threw in all excess glass. As the levels fell lower, I started to panic, and threw in MORE glass, but all I had left to toss in there were beads. Well, my opals got STUCK inside the bead holes, and smashing the beads later to get the opals out resulted in some smashed precious opals. So don't use any glass beads as filler. Actually, don't start the batch unless you have enough ceramic filler to almost fill the barrels FIRST, so you don't run low. And, if you buy new ceramic media, I'd break them in for a few days in a regular batch of rocks, so there's no sharp edges for your opals.
Only last caveat about opals. They are so temperature sensitive it's unreal. Be very very careful rinsing, and try not to TOUCH any with your hands until they have sat a few hours at room temperature. I pulled 2 out for some hand shaping... and out of all the opals, guess which ones cracked? Yep. Those 2. Of course, I went from 40 degrees to holding them in 97 degree hands, to hitting them with heat friction from the dremel too. But they were wet, and I only hit them for a few seconds with the dremel. I know well enough to keep the dremel moving and not sit in a spot building heat. Even so, those 2 cracked. I am convinced it was the heat from my hands, there was no other common denominator. Some people would say that's not possible, well, it happened, and I'm not going to keep breaking opals to prove the point:).
So when rinsing, pour into a collander, and rinse with a hose or something. Then pour carefully into a container (onto paper towel or towel), drain the water out, and take it inside to room temperature to dry. If you have to hasten drying, dry with a towel, don't TOUCH them with your hands until they have sat in room temperature a while. I try not to touch them at all until after they've dried in the jar inside the house.
Opals are probably the most temperature sensitive stones on earth, but if you are careful about that, they tumble just fine:). Hope that helps!
harmonystar
Member since December 2015
Post by harmonystar on Dec 16, 2015 23:14:13 GMT -5
harmonystar
Post by harmonystar on Dec 16, 2015 23:27:32 GMT -5
Hi...I have bought about $5000 worth of opals African /Australian opals straight from the mines so th here's lots of clay/Dirt sometime On the stones. I've tumbled and used a drumel ..with the drumel it took forever with many different grits of sandpaper+diamond cutter then a diamond polish. ..my results better but took three days to work on one piece....Can't afford a lapidary machine. .what do u use for tumbling ...I've ordered normal 5-6 step grits when tumbling. ...it seemed like I lost a ton of bulk..plus my results was nothing like I see in your picture when I tumble ... please give me pointers on how to tumble or what you use to tumble I've bought various special polishs But haven't tryed yet cause I'm afraid all my beautiful opals will get wasted like my last tumble! I had some beautiful purple and pearly blue Australian opaline bone that got ruined in my last tumble too! Please help I want to make jewelry but it looks like it's back to the drumel...please hlp !
dshanpnw
Member since December 2020
Member is Online
Post by dshanpnw on Mar 26, 2021 22:18:39 GMT -5
Hello CNH, I recently collected some Saddle mountain petrified wood which is opalized. I found a couple really nice pieces that I wanted to polish as specimens that represents Saddle mountain. I started tumbling them a week ago in 60/90 grit in a rotary tumbler and I checked them today, a week later, and they did lose a lot of volume. So after starting them on the second week in 60/90 I started wondering if I should treat this pet wood like opal, and I came to RTH for the answer, so here I am. I changed the grit to 220 and added some ceramic media. It wasn't expensive but I probably would have lost the nice pieces I was going for. Thanks to all for this thread.
gatorflash1
Post by gatorflash1 on Mar 29, 2021 7:11:57 GMT -5
Has anyone tried to tumble Bolder Opals? These have a lot of color.
Post by stefan on Mar 29, 2021 18:19:20 GMT -5
I tumbled some Boulder opal. It went as smooth as it could. I started them in 120/220 with a lot of water and plastic pellets. I ran 1 week, checked and ran a second week. Then on the 500, pre-polish, and polish. each ran a week with pellets. Had a few break, and the matrix really never took a high gloss shine, but the opal looked real nice.
