Post by jamesp on Jul 29, 2014 6:06:06 GMT -5
Crazy man... Glad your ok! Thanks man. It was safe in that oven. But at an open camp fire it would have hurt someone. It really went in all directions.
Post by jamesp on Jul 29, 2014 7:37:14 GMT -5
Yup, just water that has/had enough power to power the world for many years. I've seen pics. of steam logging donkey boilers that blew up, nothing to fool with. Pressure tanks speak volume when they blow.
transcendental
Member since June 2014
Post by transcendental on Jul 29, 2014 10:22:30 GMT -5
I had a feeling that was why but wanted to ask. Thanks for posting pics, what a difference! Beautiful
Post by 1dave on Jul 29, 2014 11:01:25 GMT -5
James, maybe you need to build a safety cage around your oven? Water+ heat = steam + pressure = bomb. Ouch! Glad there were no casualties. also = volcanoes going nuclear! We are lucky water only (?) expands 2,000 X on transition point changing to steam.
Post by jamesp on Jul 29, 2014 11:24:35 GMT -5
I had a feeling that was why but wanted to ask. Thanks for posting pics, what a difference! Beautiful It's mad scientist fiddling, never know what colors you may get.
Post by jamesp on Jul 29, 2014 11:35:37 GMT -5
James, maybe you need to build a safety cage around your oven? Water+ heat = steam + pressure = bomb. Ouch! Glad there were no casualties. also = volcanoes going nuclear! We are lucky water only (?) expands 2,000 X on transition point changing to steam. Is water the reason for volcanoes erupting Dave ?
Post by 1dave on Jul 29, 2014 11:57:57 GMT -5
also = volcanoes going nuclear! We are lucky water only (?) expands 2,000 X on transition point changing to steam. Is water the reason for volcanoes erupting Dave ? Erupting, no. Exploding, yes. Molten rock specific gravity depends on temperature and pressure. The more the rock expands, the lighter it gets, and is able to float up like a ball held under water. When it reaches rock layers with the same density it stops. Subducted rocks contain more moisture than mantle rock, and therefore lower density, and will rise higher = andesite and granite plutons. If groundwater reaches it while still HOT, Etna, St Helens, and soon Yellowstone again. BTW, did you see "Watermelon Popping" in my Family Fun post?
Post by jamesp on Jul 29, 2014 14:34:03 GMT -5
All makes sense Dave. I wonder if Old Faithful fed water to the boiler ?
Steve
Member since June 2005
Post by Steve on Jul 29, 2014 16:30:08 GMT -5
Next time anyone wants to cook a rock in the family oven when the wife (or significant other) is away they should read this post first. Wouldn't it be fun trying to explain why a new oven is in place when the wife returns from a trip?
Thanks for the post and life lesson.
Post by Pat on Jul 29, 2014 18:58:24 GMT -5
James, how can that be prevented in the future? What a surprise!
Your heat treated corals are outstanding.
Post by jamesp on Jul 29, 2014 20:36:31 GMT -5
Next time anyone want to cook a rock in the family oven when the wife (or significant other) is away they should read this post first. Wouldn't it be fun trying to explain why a new oven is in place when the wife returns from a trip? Thanks for the post and life lesson. I used to use the inside oven Steve. I would be in the dog house if that had happened in the kitchen oven for sure.
Post by jamesp on Jul 29, 2014 20:40:16 GMT -5
James, how can that be prevented in the future? What a surprise! Your heat treated corals are outstanding. Pat, simply heating it at 200F for a long time is the best you can do. Or leave it out in the sun for a year or two. if you go over 212F you risk steam buildup, and the hotter the more steam pressure. I did not notice that coral was really porous. But you never know for sure. Or cook it in a steel container full of sand. I tossed that one on top of the sand covered corals as I normally do on the 4-12 pound chunks.
Post by iant on Jul 31, 2014 1:11:53 GMT -5
Interesting to see this. As others have said, glad you are OK!
sak
Member since December 2013
Post by sak on Aug 2, 2014 0:26:48 GMT -5
Hi Jamesp -
I just wanted to point out that the strongest part of a steel structure is the welded joint (assuming it was properly welded ).
The only possibility is that it was either not welded properly causing the weld to come apart or, more than likely, the force was so extraordinary that blew out the strongest part of the container.
I can't imagine that force.
