Intheswamp
Member since September 2015
Post by Intheswamp on Mar 15, 2016 6:27:52 GMT -5
It appears there is a 15 series on the market now....SAY WHAT? !!!!!!!!! My little shop's equipment is about like me, getting old and worn out so I tend to shy away from the really low stuff.
Post by jamesp on Mar 15, 2016 6:58:50 GMT -5
It appears there is a 15 series on the market now....SAY WHAT? !!!!!!!!! My little shop's equipment is about like me, getting old and worn out so I tend to shy away from the really low stuff. Surprised the regulators let such wheels on the road. They are often brittle and vulnerable, imported and go unchecked for quality. Talk about a life support item. Lots of law suits over the years for crappy tires, wheels just as important for safety. Never use alloy for off-roading, good ole steel is reliable for that application.
Intheswamp
Post by Intheswamp on Mar 15, 2016 7:34:17 GMT -5
Corrosion is another issue with the alloy wheels. Bead area (air retention) corrodes badly on some rims, the seal is good with the old tires but when you break those old tires and off and match a new shiny bead up against a pitted, flaking mess you can expect a leaker. Sure, steel rims can rust and do the same thing but usually that is from a bad environment (farm/industrial) and a *long* tire life application...not to mention air compressors that don't get drained often enough. The alloys can corrode by the first tire change. Another issue is galvanic corrosion where the alloy wheel corrodes itself to the hub and requires <shudder) beating from the backside of the wheel to get them to come off....and some are *very* glued on!!! So yeah, steel is king (in my eyes). The draw to these wheels, other than the "look", is that a guy can take a 1984 Chevy S-10, plop some "quinties" (that's "twenties" for us English-speaking folks)and suddenly that little truck drives like a wannabe sports car....it rides like a steel-wheeled set of dollies but it drives like a Ferrari (yeah, right). The S-10 just doesn't have the suspension designed for those tires. Back when we were wholesaling, dealers would tell us that they would have customers come in on vehicles like beater Lincoln Town Cars with a $300 paint job on them, be sitting on a milk-crate (seriously) for a seat and put a set of $3000 wheels and tires on it. Now get this...they paid in fives, tens, and a few twenties. Yeah, there's some crapola out there...tires and wheels, both. Something else to be aware of are crappy lug nuts, or should I say "clad" lug nuts. These nuts have a metal covering over them that gets beat up by wrong sized sockets being used on them and from just general wear. What happens is the covering will loosen on the actual nut and suddenly you have the cover jammed up in your socket...then it's a hammer and punch to get it off and of course an uglified wheel nut. Not so bad if you're at a shop where you have a hammer and punch, BUT...if it's 10pm on a foggy night in the middle of nowhere and it happens to you with your little OE lug wrench...you're screwed...hope you have cellphone reception 'cause you're NOT getting that little metal cover out of that wrench. My question is, why the heck do the auto makers put these crappy lug nuts on a $25k+ vehicle??? I often recommend folks to change them out for solid nuts...some people do, some people don't.
Post by Deleted on Mar 15, 2016 13:03:49 GMT -5
It appears there is a 15 series on the market now....SAY WHAT? !!!!!!!!! My little shop's equipment is about like me, getting old and worn out so I tend to shy away from the really low stuff. Might as well put a eff'ing bicycle tire on it. Sheesh.
Post by jamesp on Mar 16, 2016 18:40:20 GMT -5
Intheswamp, saw a 'wheel rental' in Douglasville GA yesterday. What next ?
Post by jamesp on Mar 27, 2016 13:14:32 GMT -5
Made some $ on this order. Two 64 inch table pits with 48 inch bowls. Mom, Dad and 5 young kids will be having fun burning palm fronds in the Virgin Islands. Daddy an investment advisor. Had a list of management charges by percentage on portfolios of 5, 10, 20, and over 50 million dollars. Miami money, hmmm. The bowl with base was 350 pounds, another 100 pounds for the table top. Solved the loading issue by welding them directly on top of the pallet. Another equal sized order heading to a large estate in Dallas TX, busy week. They will be architectural planters.
Post by Deleted on Mar 27, 2016 13:15:46 GMT -5
Badass
Post by jamesp on Mar 27, 2016 13:18:02 GMT -5
Badass on the back too. Went to an auction yesterday looking at a little fork lift.
Post by Deleted on Mar 27, 2016 13:20:36 GMT -5
Not a bad call. Then you will build a boom and turn your lift into a small crane... Just saying
Cuz I know a dude like you out here and that is what he did!
Post by rockjunquie on Mar 27, 2016 13:24:03 GMT -5
Awesome!!! Good for you. Those folks have friends, too.
Post by jamesp on Mar 27, 2016 13:43:52 GMT -5
Awesome!!! Good for you. Those folks have friends, too. Will gladly take any orders their friends may request. Actually make less money per hour on custom jobs. These are new designs and am trying to get them out on the market Tela. Maybe raise price later. Fun to build.
Post by toiv0 on Mar 27, 2016 15:27:01 GMT -5
custom Gongs? I could see one mounted in a circular frame, chained on three points and wait for the dinner call
Post by jamesp on Mar 27, 2016 16:12:21 GMT -5
custom Gongs? I could see one mounted in a circular frame, chained on three points and wait for the dinner call Those things are pressed cold, they never crack. Great target for the 8 pound sledge, full wack and never crack. They have sat in a truck 10 high and wedged beyond measure in transit. Sledge hammers have been used in their separation. They also go into resonation mode when grinding, takes a long time for them to stop. Loud to grind, ear muffs best. Just don't shoot at the edge of them when they are facing you; they return bullets readily and accurately.
Post by Deleted on Mar 27, 2016 16:38:25 GMT -5
OK, so why the eff do you know that?
Post by jamesp on Mar 27, 2016 19:59:01 GMT -5
OK, so why the oops do you know that? Gets boring at the farm. Might as well liven things up from time to time.
Intheswamp
Post by Intheswamp on Mar 27, 2016 21:32:15 GMT -5
Post by jamesp on Mar 28, 2016 3:48:28 GMT -5
Gets boring at the farm. Might as well liven things up from time to time. Brought in a load of 8-10-12 inch sch 20 steel pipes on my friend's log truck years ago. Scrap iron. Some had cast iron plugs pressed in the ends. Learned that torching the end of the pipe off was the only way to remove them, which was a job. Cast iron resilient to a torch, but brittle. Thought maybe the 30.06 would crack them. Not. Shot one from 50 feet away hiding behind a tree. Copper jacket goes about 1 inch into it and ricochets straight back out and caught my Levi's just inside my calf. Pulled my legs out from under me and face planted me. Calf muscle swelled up like a balloon. Good thing it did not hit my leg. No more cast iron targets.
Post by jamesp on Mar 28, 2016 4:26:50 GMT -5
Not a bad call. Then you will build a boom and turn your lift into a small crane... Just saying Cuz I know a dude like you out here and that is what he did! I stuck this 30 X 40 barn together 25 years ago. It has been used for the nursery biz. It was originally set up as a welding fab shop. 10 inch slab and lots of steel in floor. Tricked the county into a 200 amp feed. Note 12 inch center pole up 12 feet off floor to mount crane one day. Need to organize and clean center area out and build fire pits in this barn. Buildings like this saved a fortune. Get an electrical permit and pour a slab. Prep a footing for an over sea container, have it delivered and set. Stuff it with electrical system and welder, build off of it. Collect scrap iron and weld it up at leisure. El cheap, goes up quick. Done two on the farm here at the farm and a 'cabin' down in Florida. Easy to add on to. Bought a giant 50's model welder with a flat head jeep engine to weld this up before the county gave me a permit for power. Damn thing burnt a quart of oil a day. But kicked out 400 amps and cooked 1/4 inch rods like butter. Used graphite rods to cut steel to length, again like butter. Added the high roof red section on later. For a center console boat back in the day. Good for a travel camper when body can't move any more. Right side back corner still not finished, needs purlins and metal roofing. No hurry. No code steel pipe roof construction is fast and easy. Have to prop ridge pole at center span with bamboo pole due to span on snow days. Need to fix that one. Neighbor had a boom truck he would leave at my place, I think it was stolen. Used it to set the iron. Ask no questions. plant washing/processing. Berm to the left holds a pond, ditch at base of berm is a creek which floods and carries away sediment form plant processing. 2 inch plumbing for 50 gpm pump. All rag tag scrap iron, 20 foot over sea container thrown in for electrical and compressor. Deer processing made easy. more inside Needs a clean out big time, 20 years of crap. 2 walls of shelving would take care of the mess and free up the center floor space. Going to lynch the guy that insulated this barn. There was a reign of unscrupulous insulators at the time of this construction. Got unscrupulated.
panamark
Member since September 2012
Post by panamark on Mar 28, 2016 10:11:17 GMT -5
Okay James, I gotta ask. What's the story on that awesome catfish? I need something like that for my house, ha ha.
Post by jamesp on Mar 28, 2016 11:00:10 GMT -5
Okay James, I gotta ask. What's the story on that awesome catfish? I need something like that for my house, ha ha. My friend gave me that thing. Freaks people out on a regular basis Mark.
