Post by jamesp on Jan 18, 2017 18:06:57 GMT -5
3000 pounds with one hand. Black Sabbath - "Iron Man" comes to mind...rich imaginations.
Post by jamesp on Jan 20, 2017 9:53:51 GMT -5
Reinforced fire pit cover for a 69 inch round granite table top. Ohio client is using a 48 inch fire pit for a coffee table support in his living room. Bottom of reinforced table top. Tiny welds to avoid heat warpage.
Post by wigglinrocks on Jan 20, 2017 13:28:47 GMT -5
If I was closer , I could help you unload those . In trade for some of those Rios' you've been cutting
Post by jamesp on Jan 20, 2017 13:52:57 GMT -5
If I was closer , I could help you unload those . In trade for some of those Rios' you've been cutting I like doing this work so much I have a hard time giving it to others. Sickening eh ? Still coveting the Rio's, hard to give them up too.
Post by wigglinrocks on Jan 20, 2017 17:33:33 GMT -5
Just thought I'd offer to help pull the board from under and let em roll . I like what you're doing there , taking an idea and improving it tenfold . I always like fabbing things . If I need or want something I start researching so I can build it better .
Post by jamesp on Jan 21, 2017 6:16:09 GMT -5
Just thought I'd offer to help pull the board from under and let em roll . I like what you're doing there , taking an idea and improving it tenfold . I always like fabbing things . If I need or want something I start researching so I can build it better . Got the cookie cutter designs rolling. Hope they will lead to some new prototypes. Lots of possibilities when burning wood.
Post by wigglinrocks on Jan 21, 2017 11:26:04 GMT -5
Just thought I'd offer to help pull the board from under and let em roll . I like what you're doing there , taking an idea and improving it tenfold . I always like fabbing things . If I need or want something I start researching so I can build it better . Got the cookie cutter designs rolling. Hope they will lead to some new prototypes. Lots of possibilities when burning wood. I'll try to get a pic of a firepit I put together a few years ago , may be something you would like to consider putting together . Or at least improve upon .
Post by jamesp on Jan 21, 2017 13:54:47 GMT -5
Got the cookie cutter designs rolling. Hope they will lead to some new prototypes. Lots of possibilities when burning wood. I'll try to get a pic of a firepit I put together a few years ago , may be something you would like to consider putting together . Or at least improve upon . Absolutely. Lay it out there and see what you got.
Post by rockjunquie on Jan 23, 2017 16:09:31 GMT -5
Show off! No, seriously- you work smarter, not harder.
Post by jamesp on Jan 23, 2017 17:12:27 GMT -5
Show off! No, seriously- you work smarter, not harder. Brains better than butt. And yes, a show off.
Post by jamesp on Feb 9, 2017 18:06:46 GMT -5
Building inventory for spring sales. Hopefully anyway. Funny, this greenhouse held about the same amount of money in plants as it does in fire pits. More in fire pits if the sunken areas were filled with pits.
Post by HankRocks on Feb 9, 2017 18:22:01 GMT -5
How's the Cold Fusion testing going? and you may already have come up with the perpetual motion machine, just look in the mirror.
Post by jamesp on Feb 9, 2017 18:48:28 GMT -5
How's the Cold Fusion testing going? and you may already have come up with the perpetual motion machine, just look in the mirror. Not sure what the mirror says. Aches and pains a bigger concern. Shut the reactor down for a tumbling experiment. Tumbling more complicated than cold fusion.
Post by HankRocks on Feb 9, 2017 19:34:50 GMT -5
Rock Tumbling is definitely a lot more complicated now that I have been reading this Forum. let's see; Rock fill level, water fill level, mixture of rocks, Size of Rocks, Slurry, Speed of Barrel, Recharging, Coarser Grit, AO, Ceramics, Plastic Pellets, pre-grinding, diamond grinding, and probably more that I missed. If Barometric Pressure, Humidity and Phase of the Moon ever become important I may have to find a new hobby!!
Just kidding, keep up the good work!!
H
Post by jamesp on Feb 10, 2017 8:51:29 GMT -5
Rock Tumbling is definitely a lot more complicated now that I have been reading this Forum. let's see; Rock fill level, water fill level, mixture of rocks, Size of Rocks, Slurry, Speed of Barrel, Recharging, Coarser Grit, AO, Ceramics, Plastic Pellets, pre-grinding, diamond grinding, and probably more that I missed. If Barometric Pressure, Humidity and Phase of the Moon ever become important I may have to find a new hobby!! Just kidding, keep up the good work!! H Recipe involving proper mix and timing of SiC 30, AO 80, clay, water, rocks, barrel, rotation. Pre-grinding as needed. To get to that point took a do do load of trials. the cold fusion not so simple....
Post by Fossilman on Feb 10, 2017 10:41:32 GMT -5
Granny's secret recipe....... Looks like you got it going James.... Thumbs up
Post by jamesp on Feb 10, 2017 10:51:08 GMT -5
Granny's secret recipe....... Looks like you got it going James.... Thumbs up In this case Grand Pa. Granny limits herself to the kitchen. Better that way, me no cook.
Post by jamesp on Mar 2, 2017 4:40:58 GMT -5
Ohio client contrives interesting coffee table out of 48" fire pit. He had me weld tabs to center this 60" roll top cover to center it to support a 67" Lapland Green marble top: Completed piece: Italian Lapland Green marble
Post by captbob on Mar 2, 2017 10:05:47 GMT -5
Is that base sealed (spray coated) with something? Wondering if it is going to leave a rust ring on their carpet.
Does make a darn good lookin' table.
Post by melhill1659 on Mar 2, 2017 11:10:48 GMT -5
Ohio client contrives interesting coffee table out of 48" fire pit. He had me weld tabs to center this 60" roll top cover to center it to support a 67" Lapland Green marble top: Completed piece: Italian Lapland Green marble WOW WOW WOW!
