Post by jamesp on May 4, 2016 16:21:37 GMT -5
Bushing and bad boy 30 grit
Post by Fossilman on May 4, 2016 16:35:44 GMT -5
Git R Done!!! Looks like Scott is on a roll now!!!
grayfingers
Member since November 2007
Post by grayfingers on May 4, 2016 16:44:54 GMT -5
Pretty cool there, Scott! Those Montanas take some time to tumble whole (sans pre-smoothing). Good thing your tumbler is in 5th gear!
Post by Deleted on May 4, 2016 17:49:04 GMT -5
Thanks Mike, Bill and Jim.
I will shop bushings and make a new barrel. Im unhappy with this one anyways! Within 1/4" too long. Barely fits.
Post by Deleted on May 4, 2016 17:50:30 GMT -5
Bushing and bad boy 30 grit Can you show me the whole barrel with a bushing reducer?
Post by Deleted on May 4, 2016 18:03:00 GMT -5
Pretty cool there, Scott! Those Montanas take some time to tumble whole (sans pre-smoothing). Good thing your tumbler is in 5th gear! They can spin a long ime. I aint in a hurry. Wanna see what they look like whole! Overdrive tumbler. Maybe need to make an aquarium stand style tumbler like Chuck. Slow it down a bit and quieter, more reliable.
Post by Deleted on May 4, 2016 18:04:56 GMT -5
What's that glowing yellow rock near the bottom- looks like it needs a Geiger counter. Uncle you are so right. I will see Dan saturday. Maybe he will help,then.
Post by Deleted on May 4, 2016 18:05:52 GMT -5
Crap.
It looks like I have to buy 10' of 4"!
So i can cut a 4" section.... Dang.
Finally!!
May 4, 2016 19:36:04 GMT -5
via mobile
Post by orrum on May 4, 2016 19:36:04 GMT -5
Ur gonna be addicted Scott!
Post by Deleted on May 4, 2016 20:00:22 GMT -5
Ur gonna be addicted Scott! I was on a roll, 5 years ago. Then, the fan belt broke the same day I started a new job. Finally got back. I have a huge pile of some very nice stones. When I make my quartz purple vibe, I will be styling. Chilling like jamesp! That is if my vibe will break down AO into polish like his viking.
Post by Drummond Island Rocks on May 4, 2016 20:08:57 GMT -5
The more the merrier. Looking forward to some nice tumbled stone pictures from you.
Post by spiceman on May 4, 2016 20:37:14 GMT -5
Well, it just be luck for me but I used chap stick on my threads and had no troubles with stage one. Running stage2 now and will see after that.
Finally!!
May 4, 2016 20:52:00 GMT -5
via mobile
Post by Deleted on May 4, 2016 20:52:00 GMT -5
Chapstick is a good idea!
Post by Deleted on May 4, 2016 20:53:32 GMT -5
The more the merrier. Looking forward to some nice tumbled stone pictures from you. Chuck Thanks Chuck. Maybe I enter the 2017 worlds! lol
Post by jamesp on May 4, 2016 21:16:47 GMT -5
The bushing is just a standard 6-4 with a stub of 4 inch pipe glued into it. Glue it into one side of coupling, pipe into other side. One sitting on end:
Finally!!
May 4, 2016 21:30:50 GMT -5
via mobile
Post by Deleted on May 4, 2016 21:30:50 GMT -5
The bushing is just a standard 6-4 with a stub of 4 inch pipe glued into it. Glue it into one side of coupling, pipe into other side. One sitting on end: Thanks. The reason I asked, is the bushing I found looks different. I'm afraid it would be same diameter as the end cap.
Post by Deleted on May 5, 2016 12:09:08 GMT -5
I opened after 20 hours. Slurry like milk, not milkshake. Tons of room inside. Added a few stones, and a cup of dry clay. Cleared the threads of grit and reset cap. Ordering new barrel parts using jamesp bushing method.
Post by jamesp on May 5, 2016 12:20:19 GMT -5
I opened after 20 hours. Slurry like milk, not milkshake. Tons of room inside. Added a few stones, and a cup of dry clay. Cleared the threads of grit and reset cap. Ordering new barrel parts using jamesp bushing method. Dial it in Scott. Experiment till slurry is right. Just remember how much kitty litter you added. 2-3 cups for GA red clay for 20 pounds. Bushing makes a tough barrel. I have been squeezing silicon caulk blob in bottom of round face cap and then pressing a 6 inch paper plate down on the blob to flatten it. Silicon laughs at grit and rocks, however if it delaminates it can catch abrasives.
Post by Deleted on May 5, 2016 12:50:51 GMT -5
Maybe rough the surface up and pour epoxy in. Self leveling, very flat.
Intheswamp
Member since September 2015
Post by Intheswamp on May 5, 2016 13:14:39 GMT -5
Well, I take a nap and look what happens....SHAZAMMM!!!!! Scott building pvc barrels!!!! Lookin' good, Scott!
