Post by johnjsgems on Jul 24, 2017 11:06:37 GMT -5
Tile blade super grinders last a long time and very durable. The old club where we used to live had to put their super grinder outside because of the noise though. I saw it after three years hard club use and blades still looked new. It had about 10 ea. 10" tile blades.
Post by wigglinrocks on Jul 24, 2017 13:13:30 GMT -5
@shotgunner , on the continuous blades with no spacer , what grit wheel would you compare the blades to , 60 , 80 or more coarse ?
Post by Deleted on Jul 24, 2017 13:46:25 GMT -5
@shotgunner , on the continuous blades with no spacer , what grit wheel would you compare the blades to , 60 , 80 or more coarse ? No clue. I'll ask the vendor.
Post by wigglinrocks on Jul 24, 2017 13:54:46 GMT -5
@shotgunner , on the continuous blades with no spacer , what grit wheel would you compare the blades to , 60 , 80 or more coarse ? No clue. I'll ask the vendor. Just curious , thanks .
Post by Deleted on Jul 24, 2017 14:21:40 GMT -5
@shotgunner , on the continuous blades with no spacer , what grit wheel would you compare the blades to , 60 , 80 or more coarse ? I think I understand your question better. Lemme get it working and I'll test both. But certainly more aggressive than 80 grit
Post by Garage Rocker on Jul 24, 2017 14:49:33 GMT -5
That new work shop better have an expandable back wall. Equipment builds/purchases coming fast and furious.
Post by wigglinrocks on Jul 24, 2017 15:46:07 GMT -5
@shotgunner , on the continuous blades with no spacer , what grit wheel would you compare the blades to , 60 , 80 or more coarse ? I think I understand your question better. Lemme get it working and I'll test both. But certainly more aggressive than 80 grit I was thinking if they weren't too aggressive they would work in place of an 80 hard wheel .
Post by Deleted on Jul 24, 2017 15:51:43 GMT -5
I think I understand your question better. Lemme get it working and I'll test both. But certainly more aggressive than 80 grit I was thinking if they weren't too aggressive they would work in place of an 80 hard wheel . The goal is to take the major cutting away from those expensive wheels. Then all the 80 does is clean up the roughing work the supergrinder does.
Post by wigglinrocks on Jul 24, 2017 16:08:25 GMT -5
I was thinking if they weren't too aggressive they would work in place of an 80 hard wheel . The goal is to take the major cutting away from those expensive wheels. Then all the 80 does is clean up the roughing work the supergrinder does. I have a 100 sic wheel thats days are numbered on the opposite end of the super . Thinking of putting on a stack unspaced the way you did to try and get away from the high buck wheel .
Post by Psycho on Sept 28, 2017 20:06:49 GMT -5
Either way you look at it Scott it is a great idea and use of some extra parts, with a great concept to go with it. I love it, diy Lapidary at its finest. Frank
Post by Deleted on Sept 28, 2017 22:56:14 GMT -5
Either way you look at it Scott it is a great idea and use of some extra parts, with a great concept to go with it. I love it, diy Lapidary at its finest. Frank Thanks Frank. If I could just finish it and get it running. lol
