Post by miket on Apr 30, 2019 16:09:12 GMT -5
Finished grinding the above, here's what I came up with. A little bit fewer vugs, some brighter reds, a little less of the orange- I would have liked it to have ended up with some more of the orange but the rock wants what it wants. Anyway, into the rotary it goes. Thanks for looking!
Grrrr
Apr 30, 2019 16:17:04 GMT -5
Post by stardiamond on Apr 30, 2019 16:17:04 GMT -5
I see an exceptional cab from a recut. Draw a line from the left edge of the white past the right shiny spot and arc it toward the bottom. Work out a shape that pleases you.
Grrrr
Apr 30, 2019 16:37:15 GMT -5
Post by miket on Apr 30, 2019 16:37:15 GMT -5
I see an exceptional cab from a recut. Draw a line from the left edge of the white past the right shiny spot and arc it toward the bottom. Work out a shape that pleases you. Basically that would remove those larger vugs on the right side... I might just do that, thanks.
Grrrr
Apr 30, 2019 16:42:58 GMT -5
miket likes this
Post by stardiamond on Apr 30, 2019 16:42:58 GMT -5
For a piece of material that a person likes, it is typical to try to make the largest cab possible. I've done that many times over the years. Bigger is not always better.
