Post by miket on Apr 29, 2020 14:23:52 GMT -5
If you are happy with the shape, you are done. Look at it for a while an consider possible adjustments. My eye tells me to move in the left side lower half in a bit. Ok, will do. Thanks. That's why I needed some fresh eyes- I wasn't happy with the way it is. And I trust your eye, you produce some excellent shapes!
Post by miket on Apr 29, 2020 14:24:45 GMT -5
Fresh off the dremel app miket Beat me to it, that inside curve on the right is a good idea, I think it will still need a touchup elsewhere but it's getting close. Thanks, I'll see what I can do with it!
Post by Peruano on Apr 29, 2020 16:34:35 GMT -5
I would bet a dollar to a donut that if you had been working on cab machine instead of a Dremel, the question would not have come up. You would have just gone to the side that offended your eye and rectified the shape in a few seconds. Its amazing how things can be saved, or ruined and re-shaped very quickly in this game. You are doing fine and doing it the hard way.
Post by miket on Apr 29, 2020 16:41:31 GMT -5
I would bet a dollar to a donut that if you had been working on cab machine instead of a Dremel, the question would not have come up. You would have just gone to the side that offended your eye and rectified the shape in a few seconds. Its amazing how things can be saved, or ruined and re-shaped very quickly in this game. You are doing fine and doing it the hard way. Thank you sir, I appreciate the kind words! I'm guessing you're right- I've been able to save, ruin and reshape the way I'm doing it but it sure does take a bit of work. I'll get this one, too.
Post by hummingbirdstones on Apr 29, 2020 20:47:31 GMT -5
You'll get it how you want, I have no doubt. Sometimes tracing the shape on graph paper helps to see where you need to do some fixing.
Post by miket on Apr 30, 2020 9:28:13 GMT -5
You'll get it how you want, I have no doubt. Sometimes tracing the shape on graph paper helps to see where you need to do some fixing. Thanks for the tip! See below...
Post by miket on Apr 30, 2020 9:30:28 GMT -5
So, apparently this one wanted to be an oval. I had the perfect shape I wanted and the entire tip snapped off and hit the floor. An out-of-character word went out into the universe. I lost quite a bit of the black plumes that I liked in the stone but I think I saved it. So off to the tumbler it goes...
