Post by Mel on Aug 30, 2020 13:18:01 GMT -5
Like the subject says. They're rolling unevenly, like they've become "oval" or "stretched" I'm looking into a Lortone ASAP but it's gonna be a few weeks yet. Also, the motor on my CE dual is making the most godawful noises. I have done all the maintenance required, but it's still howling like a banshee to the point I've had to turn it off to be able to think. It runs in a corner of my "office" and has, up till now, been pretty quiet. Like I said, going to replace ASAP, but anyone got any suggestions for the meantime? Thanks in advance! Is it the motor making the noise, or the rollers? Mine was whining and my DH took off the end caps over the rollers and gave me a tube of "multi-vehicle high temperature red grease" (Valvoline) to apply. Quieted right down. I keep mine in a cardboard box. That may help with noise, I mostly started because I was paranoid it would leak and make a mess. Reeniebeany Not quite what you asked, but that black tab on the top of the frame should be turned about 90 degrees; it pushes the barrel away from the frame. Should fix you right up.
