Post by miket on Nov 22, 2020 8:09:09 GMT -5
Just saw this, fantastic!
Post by taylor on Nov 22, 2020 13:12:05 GMT -5
Hi Taylor's I read that comment about gluing your fingers are you using super glue for the joints? Yes, super glue for the framing joints. Epoxy for the back piece. I had forgotten that regular super glue is sooo thin! Next bottle will be the gel type!
Post by mohs on Nov 22, 2020 13:29:05 GMT -5
Interesting Taylor's That gel type super glue is what I use for setting the eyepins figure it little thicker and will hold better man tho -working with super glue is tricky and noticing my hands are shaking more really increases the difficulties have to say your really good putting seams together with super that seems doubly tricky I like the epoxy cause it gives set time anyway seam on! ![;)](//storage.proboards.com/forum/images/smiley/wink.png)
Post by taylor on Nov 22, 2020 13:36:27 GMT -5
Thanks mohs . The process makes the gluing easier than it looks! The frame pieces start out longer and thicker than the centerpiece, so the messiness gets ground away.
