USMC15
I feel like I just came out of the tumbler ...
Member since March 2021
Post by USMC15 on Mar 10, 2021 14:06:40 GMT -5
USMC15
Post by USMC15 on Mar 10, 2021 14:42:39 GMT -5
I didn't take pictures of all the rocks. I'm saving my patients for the tumbling. I still have Botswana agate and Mexican lace agate to post. Stay tuned.
Post by stephan on Mar 10, 2021 15:08:25 GMT -5
I'll be keeping an eye on that bloodstone. I love that stuff.
Not a tumbler, so I can't give any experience-based advice on how ready they are for promotion. based on what I've read in other threads, though, I sse some cracks (in numbers 3, 4, 5) that look like they could trap grit that would cause you grief in later stages.
USMC15
Post by USMC15 on Mar 10, 2021 15:13:50 GMT -5
Stupid question, which one is bloodstone?
Post by jasoninsd on Mar 10, 2021 15:25:05 GMT -5
I think they're making progress. I think they need to back into stage one again though...too many pits and fissures left.
Post by miket on Mar 10, 2021 15:26:52 GMT -5
Not bad so far, but I would give them a little more time. Tumbling takes a TON of patience. But it's worth it!
USMC15
Post by USMC15 on Mar 10, 2021 15:31:10 GMT -5
USMC15
Post by USMC15 on Mar 10, 2021 15:32:13 GMT -5
Yes, all of them are going back into stage 1
USMC15
Post by USMC15 on Mar 10, 2021 15:36:13 GMT -5
One more barrel to clean out. Stay tuned.
Post by jasoninsd on Mar 10, 2021 15:41:11 GMT -5
I'd like to see some input from some of the more experienced tumblers, but a lot of those stones are looking like they have "bruising" from high impact with the other stones during tumbling. If that's the case, I think the solution is more smalls to "cushion" during the tumble.
Again, I wouldn't act on what I said until a few more people with experience chime in...
USMC15
Post by USMC15 on Mar 10, 2021 16:00:50 GMT -5
I have a mix of ceramic media in the barrel. I added 8 tablespoons of 80 grit, don't know if that will make a difference.
USMC15
Post by USMC15 on Mar 10, 2021 16:30:08 GMT -5
USMC15
Post by USMC15 on Mar 10, 2021 16:38:24 GMT -5
That is the rest of the Cleanout. I will do a week two next week.
Post by miket on Mar 10, 2021 17:25:46 GMT -5
They're going to be fantastic!
Post by hummingbirdstones on Mar 10, 2021 19:35:10 GMT -5
This one is the Bloodstone -- actually Fancy Jasper. Bloodstone doesn't have the yellow in it.
USMC15
Post by USMC15 on Mar 10, 2021 20:38:34 GMT -5
This one is the Bloodstone -- actually Fancy Jasper. Bloodstone doesn't have the yellow in it. Nice, bonus with my purchase
stewdogg
Member since January 2020
Post by stewdogg on Mar 11, 2021 10:12:17 GMT -5
I have a mix of ceramic media in the barrel. I added 8 tablespoons of 80 grit, don't know if that will make a difference. How big is your barrel? I usually have a loose and fast rule about grit, about one tablespoon of grit per pound of barrel. So, a 3lb barrel would get 3 tablespoons of grit and a 12lb barrel get 12 tbs of grit. Also how full do you fill the barrel? If there's too much space, it allows the rocks to fall further and have a bigger impact at the bottom of the barrel.
USMC15
Post by USMC15 on Mar 11, 2021 10:25:09 GMT -5
I have a mix of ceramic media in the barrel. I added 8 tablespoons of 80 grit, don't know if that will make a difference. How big is your barrel? I usually have a loose and fast rule about grit, about one tablespoon of grit per pound of barrel. So, a 3lb barrel would get 3 tablespoons of grit and a 12lb barrel get 12 tbs of grit. Also how full do you fill the barrel? If there's too much space, it allows the rocks to fall further and have a bigger impact at the bottom of the barrel. I have 6lbs barrels and yes I do the 1 for 1. I added 2 more to the Botswana to test results and see if it will remove the white marks. If anything I have the barrels too full, hope not, but I know there is plenty of material in the barrels.
Post by Fossilman on Mar 11, 2021 12:20:59 GMT -5
Just a question - Was your agates fractured before the tumbling stages?
USMC15
Post by USMC15 on Mar 11, 2021 13:22:28 GMT -5
Just a question - Was your agates fractured before the tumbling stages? Yes they were bought from www.rockshed.com
