Post by fernwood on Oct 6, 2022 7:34:06 GMT -5
Has anyone used battery powered LED lights to backlight small, polished rock slabs? I had to purchase some of these for wreaths I need to make for work. There is bare wire between the lights. They are cool. Turns out I found a package of 12 for $2.00 more than a package of 6. So I got 12. I only needed 6 for the wreaths. Have been experimenting on how to position and attach them to the back of slabs. I just taped them to the back of a slab on the photo. Am thinking it would be better to bend the wire, so the lights are spaced out more. Then attach the lights to a backing of sorts. Use something to space the backing at least 1/4" from the slab. That way, there should not be blobs of light, but more even light. Any thoughts? Thanks.
wampidytoo
Add 5016 to my post count.
Member since June 2013
Post by wampidytoo on Oct 6, 2022 21:18:21 GMT -5
On monitors and TVs they use light diffusers in groups that might help.
Post by RWA3006 on Oct 10, 2022 19:59:20 GMT -5
Here's a large slab of dino bone that's framed and backlit with LED.
Post by Rockoonz on Oct 11, 2022 1:57:45 GMT -5
I was thinking shadow box like RWA3006 with a diffusor behind the slab or slabs and a glass face as well. Elizabeth made slab night lights when we were selling at holiday bazaars.
Post by jamesp on Oct 12, 2022 9:40:44 GMT -5
Post by jamesp on Oct 12, 2022 10:12:48 GMT -5
12 for $2 will be hard to beat Beth.
khara
Member since September 2022
Post by khara on Oct 18, 2022 15:38:20 GMT -5
Has anyone used battery powered LED lights to backlight small, polished rock slabs? I had to purchase some of these for wreaths I need to make for work. There is bare wire between the lights. They are cool. Turns out I found a package of 12 for $2.00 more than a package of 6. So I got 12. I only needed 6 for the wreaths. Have been experimenting on how to position and attach them to the back of slabs. I just taped them to the back of a slab on the photo. Am thinking it would be better to bend the wire, so the lights are spaced out more. Then attach the lights to a backing of sorts. Use something to space the backing at least 1/4" from the slab. That way, there should not be blobs of light, but more even light. Any thoughts? Thanks. Hot melt glue could work, can be built up to create thickness and space. Years ago I made a fun Christmas tree light chain by gluing small tumbled translucent agates to a string of clear Christmas lights.
