ericabelle
Instagram acct: @erica_shoots_everything
Member since April 2021
Post by ericabelle on Oct 8, 2022 20:04:46 GMT -5
I'm interested to know if you prep your rocks before tumbling in any way to speed the shaping process along. And what do you use? (dremel, flat lap, saw, etc.)
vance71975
Member since September 2022
Post by vance71975 on Oct 8, 2022 20:29:40 GMT -5
I'm interested to know if you prep your rocks before tumbling in any way to speed the shaping process along. And what do you use? (dremel, flat lap, saw, etc.) I will some times knock off lips or small protrusions or split them in the case of a bad crack with a chisel. I have ground some Holes or nubs i could not get off with a chisel using a belt sander with SiC belts but that is a VERY slow process and would not suggest it. I have not got the right discs and burrs for my Dremel yet but I will do shape ups with it once I do.
Post by jasoninsd on Oct 8, 2022 20:37:22 GMT -5
Sometimes I'll use my trim saw...sometimes the slab saw - depending on how badly the issues are. I have also preshaped obsidian on the cabbing wheels...
pebblesky
Post by pebblesky on Oct 8, 2022 21:54:10 GMT -5
I only have access to a hammer so far, and I use it to get rid of the faulty ends of thin rocks.
I really should try the dremel tomorrow...
mjflinty
Member since September 2011
Post by mjflinty on Oct 9, 2022 5:42:30 GMT -5
I'm a flintknapper and I tumble a good bit of my chert debris; I will shape some pieces to remove thin edges or 90 degree angles. It does speed up the rough grind!
ericabelle
Post by ericabelle on Oct 9, 2022 7:52:57 GMT -5
Thanks for all the responses - I'm definitely going to have to start doing this! I have a lot of pieces with sharp edges - mostly chert and chalcedony - that take a very long time to smooth in the tumbler. And even then, they wind up keeping their angular shape. Sometimes that looks good, and sometimes I'd rather them have a rounder shape.
quartzilla
Member since April 2020
Post by quartzilla on Oct 9, 2022 8:24:57 GMT -5
I will saw off troublesome areas before starting. I also will use the flat lap to further shape, remove pits, and remove spalls and other flaws after they have run a while and I can determine it the stone is worth the extra effort or not.
