Post by catmandewe on Oct 17, 2022 19:51:41 GMT -5
I took a quick trip to Montana to pick up some big tumblers from a friend of mine. One of these tumblers will take approx 500-750 lbs of rock, the other one is only about a 3-400 pounder. I think I am going to play with the smaller one and see how it works out. When I get some tumbles going I will take pictures. Tony
brybry
Enter your message here...
Member since October 2021
Post by brybry on Oct 17, 2022 20:08:32 GMT -5
Nice! My wife is expecting me to show up with a converted cement mixer. She'd have a litter of kittens if I showed up with those.
Post by Deleted on Oct 17, 2022 21:04:42 GMT -5
Thats insane looking Tony! Looking forward to seeing the reports.
rockbrain
Member since January 2022
Post by rockbrain on Oct 17, 2022 21:07:29 GMT -5
Looks like you got rocks to load in it too!
vance71975
Member since September 2022
Post by vance71975 on Oct 17, 2022 22:52:09 GMT -5
I took a quick trip to Montana to pick up some big tumblers from a friend of mine. One of these tumblers will take approx 500-750 lbs of rock, the other one is only about a 3-400 pounder. I think I am going to play with the smaller one and see how it works out. When I get some tumbles going I will take pictures. Tony What does that that 50lbs Of Grit?
pebblesky
Post by pebblesky on Oct 17, 2022 22:55:15 GMT -5
Looking forward to your further reports!
vance71975
Post by vance71975 on Oct 17, 2022 23:33:09 GMT -5
Seriously tho, How much Grit would you need to load in for 400lbs of rocks, and how many gallons of water? Serious question cause im curious now.
vance71975
Post by vance71975 on Oct 17, 2022 23:36:11 GMT -5
If you go 4 tablespoons per lb of rocks, that comes out to roughly 50lbs of grit, and I threw that number off the top of my head half joking, but I just did the math, and WOW that is A LOT OF GRIT for 1 batch.
Post by jamesp on Oct 18, 2022 1:06:35 GMT -5
Mass production !
JR8675309
Member since August 2019
Post by JR8675309 on Oct 18, 2022 6:15:50 GMT -5
It's good to see I'm not alone in crossing the state line for equipment . Good for you catmandewe
Post by catmandewe on Oct 18, 2022 10:26:53 GMT -5
I have some 50 lb sacks of 80 grit Aluminum oxice, going to just dump one sack in and see how it does. The big one is just a large single drum. The smaller one has a double drum container. Hard part is going to be finding enough smalls to keep them from beating each other up. I will check with my local body shop and see if they will save me a couple buckets of broken safety glass.
vance71975
Post by vance71975 on Oct 18, 2022 11:38:37 GMT -5
I have some 50 lb sacks of 80 grit Aluminum oxice, going to just dump one sack in and see how it does. The big one is just a large single drum. The smaller one has a double drum container. Hard part is going to be finding enough smalls to keep them from beating each other up. I will check with my local body shop and see if they will save me a couple buckets of broken safety glass. Well, If you want to tumble small Boulders you are set man! lol I mean you could load that thing with a massive load of 5lb to 20lb rocks. Might consider the garden department at wal mart and some cheap landscaping rocks for smalls. Couple 3 bags of those at the link below would likely work for smalls if you are gonna run a batch of Bigger rocks anyway. Just a thought. www.walmart.com/ip/Mexican-Beach-Pebbles-Round-River-Rock-Landscape-Garden-Stones-20-pounds/385699283
lyle
Member since October 2022
Post by lyle on Oct 25, 2022 16:00:10 GMT -5
Ha! I thought I was doing good with my 5 gal. bucket tumbler!
