Post by vegasjames on Dec 3, 2022 9:29:32 GMT -5
rockbrain
Member since January 2022
Post by rockbrain on Dec 3, 2022 10:08:55 GMT -5
That's an incredible looking piece of machinery. I think it might be a tad out of my price range. I think the blade might be a tad out of my price range!
herb
Post by herb on Dec 3, 2022 10:53:01 GMT -5
Wow! A 45 inch saw! I wonder if it is going to come with a crane for lifting the rocks up!
I like the idea of the controller being able to slow down the feed or even stop cutting all together based on the current draw of the motor. Should help make smoother cuts. Prolong blade life, and help prevent disasters.
I heard about the automated saw awhile ago. Another great idea! Although trying to automatically cut a piece of rough that has pieces fracturing off could cause issues
Post by RWA3006 on Dec 3, 2022 11:37:06 GMT -5
Interesting. Reminds me of when I used to run a lumber sawmill with a 52" blade. The beast had a 3/8" kerf and a giant German diesel engine to drive it. I quickly learned why band saw style mills rendered my mill obsolete, because any slight shifting or twisting would bind the blade and warp it from heat building up.
Another issue is it's really hard to load the carriage with such heavy stock without knocking it out of alignment or damaging it.
My gut tells me this new saw might be too much of a good thing and something like a band saw, or wire saw might be more practical.
Post by Rockoonz on Dec 3, 2022 12:46:56 GMT -5
45" and not 48"? I assume so that they are the only source for blades? I do like the load sensing feed motor. Somewhere in the archives is my "frankensaw" thread, not looking it up now. I found this home made 12" saw built inside a HF parts washer tub for much less than the cost of a new 12" blade at the time, I think like $30 bucks. I cut a few rocks with it, grenaded the stepper feed motor because the builder had used the stepper bearing to support the feed screw, so I parted it out. There was no split nut, it had adjustable limit switches for the start and end of travel and put the feed motor into full speed reverse at the end of a cut. The control box has relays that would support 20A and the timers to do the rest, all old school solid state. I still have the control box and limit switches It had a nice almost new motor that ended up somewhere in another machine that is probably long gone. I wonder if I should try something with the next needy saw tub I find just for fun. NOT the auto slabber of course, don't trust rocks to CNC myself, if you need more slabs faster get more saws. sphereguy Matt tells me that they start cutting faster than you can keep up with at about 10 saws running, maybe one day I can test that theory.
Post by Rockoonz on Dec 4, 2022 2:49:26 GMT -5
