Post by jamesp on Dec 29, 2022 13:01:58 GMT -5
This is a homemade barrel of 8" HDPE pipe fittings after a 6 week run using "time release" giant SiC. The cap was never removed during the 6 week run. Gas pressure build up was substantial. The band clamp was loosened slowly to let the air pressure leak out first to avoid it being a missile. giant SiC after 6 weeks. it should last thru the entire step 1. clay slabs plucked off the top of a dried up mud puddle for slurry additive
pebblesky
Member since September 2022
Post by pebblesky on Dec 29, 2022 13:38:37 GMT -5
Looks super cool! What are the giant SiC?
Post by jamesp on Dec 30, 2022 7:06:16 GMT -5
Looks super cool! What are the giant SiC? It is a 90% pure bulk metallurgical grade of SiC used for adding to molten steel to alter its properties. Made by Washington Mills. About 50% of it has those large garbanzo bean sized SiC chunks in it, the rest is SiC 20-30-40-50... ungraded particles. Easy to screen and separate by size. It was cheap at only 40 cents per pound and came in 50 pound bags.
pebblesky
Post by pebblesky on Dec 30, 2022 19:19:52 GMT -5
Looks super cool! What are the giant SiC? It is a 90% pure bulk metallurgical grade of SiC used for adding to molten steel to alter its properties. Made by Washington Mills. About 50% of it has those large garbanzo bean sized SiC chunks in it, the rest is SiC 20-30-40-50... ungraded particles. Easy to screen and separate by size. It was cheap at only 40 cents per pound and came in 50 pound bags. Thanks James. It's amazing that there are so many things customized in your tumbling.
Post by RickB on Dec 30, 2022 19:33:36 GMT -5
vance71975
Post by vance71975 on Dec 30, 2022 23:39:31 GMT -5
Looks super cool! What are the giant SiC? It is a 90% pure bulk metallurgical grade of SiC used for adding to molten steel to alter its properties. Made by Washington Mills. About 50% of it has those large garbanzo bean sized SiC chunks in it, the rest is SiC 20-30-40-50... ungraded particles. Easy to screen and separate by size. It was cheap at only 40 cents per pound and came in 50 pound bags. where exactly do you get that?
Post by jamesp on Dec 31, 2022 5:22:34 GMT -5
It is a 90% pure bulk metallurgical grade of SiC used for adding to molten steel to alter its properties. Made by Washington Mills. About 50% of it has those large garbanzo bean sized SiC chunks in it, the rest is SiC 20-30-40-50... ungraded particles. Easy to screen and separate by size. It was cheap at only 40 cents per pound and came in 50 pound bags. where exactly do you get that? It was a wholesale bulk product back in 2016 Vance. Best way to purchase would be to contact Washington Mills Inc. and ask them.
Post by jamesp on Dec 31, 2022 5:26:13 GMT -5
jamesp, a 30 gallon trash can full of beautiful red Georgia clay for slurry. No shortage of red clay in these parts Rich ! Odd they call it Georgia red clay, every state in the south is loaded with it.
Post by jamesp on Dec 31, 2022 5:29:55 GMT -5
It is a 90% pure bulk metallurgical grade of SiC used for adding to molten steel to alter its properties. Made by Washington Mills. About 50% of it has those large garbanzo bean sized SiC chunks in it, the rest is SiC 20-30-40-50... ungraded particles. Easy to screen and separate by size. It was cheap at only 40 cents per pound and came in 50 pound bags. Thanks James. It's amazing that there are so many things customized in your tumbling. Abnormality of being an engineer perhaps pebblesky.
Post by RickB on Dec 31, 2022 11:51:41 GMT -5
jamesp, a 30 gallon trash can full of beautiful red Georgia clay for slurry. No shortage of red clay in these parts Rich ! Odd they call it Georgia red clay, every state in the south is loaded with it. James we have plenty of red clay here in South Carolina and I've dug through a lot of it. It just doesn't compare to the tough stuff that you have in Georgia. I've been to quite a few digs in Georgia through the years digging for amethyst, quartz and rutile. Maybe it is the type of granite you have that it decomposes from.
Post by jamesp on Dec 31, 2022 13:57:10 GMT -5
No shortage of red clay in these parts Rich ! Odd they call it Georgia red clay, every state in the south is loaded with it. James we have plenty of red clay here in South Carolina and I've dug through a lot of it. It just doesn't compare to the tough stuff that you have in Georgia. I've been to quite a few digs in Georgia through the years digging for amethyst, quartz and rutile. Maybe it is the type of granite you have that it decomposes from. Probably the lack of sand content here Rick. Because of the massive worn down granitic Appalachians the kaolin clay deposited from them in north/middle Georgia is very pure. It is the higher sand content that makes for easier digging.
dogstar23
Member since May 2023
Post by dogstar23 on May 5, 2023 7:43:09 GMT -5
New to the hobby but has anyone tried using distilled water to reduce blowouts? I make my own moonshine so no problem getting plenty of distilled water.
Wooferhound
Lortone QT66 and 3A
Member since December 2016
Post by Wooferhound on May 5, 2023 16:26:40 GMT -5
New to the hobby but has anyone tried using distilled water to reduce blowouts? I make my own moonshine so no problem getting plenty of distilled water. Blowouts are generally caused by the reaction of the rock to the water. Tumbling Glass will release a lot of gas too. And sometimes you can do the same tumble 15 times, and the 16th time you do it will be a blowout for No Reason at all. I check the barrels on the tumblers all the time, at least every 2 days looking for gas expansion.
Post by velodromed on Aug 23, 2023 6:51:48 GMT -5
This is a homemade barrel of 8" HDPE pipe fittings after a 6 week run using "time release" giant SiC. The cap was never removed during the 6 week run. Gas pressure build up was substantial. The band clamp was loosened slowly to let the air pressure leak out first to avoid it being a missile. giant SiC after 6 weeks. it should last thru the entire step 1. clay slabs plucked off the top of a dried up mud puddle for slurry additive Sorry to pull up an old post, but I’m really interested in your home made barrel. Where did you get the material for the barrel itself? I found HDPE pipe covers but couldn’t find anything like the barrel you show. I’d also love to see your home built tumbler. Is there a post showing how you built it? many thanks! Doug
Post by hummingbirdstones on Aug 23, 2023 10:59:57 GMT -5
This is a homemade barrel of 8" HDPE pipe fittings after a 6 week run using "time release" giant SiC. The cap was never removed during the 6 week run. Gas pressure build up was substantial. The band clamp was loosened slowly to let the air pressure leak out first to avoid it being a missile. giant SiC after 6 weeks. it should last thru the entire step 1. clay slabs plucked off the top of a dried up mud puddle for slurry additive Sorry to pull up an old post, but I’m really interested in your home made barrel. Where did you get the material for the barrel itself? I found HDPE pipe covers but couldn’t find anything like the barrel you show. I’d also love to see your home built tumbler. Is there a post showing how you built it? many thanks! Doug Doug, here's one. I know there are probably more if you search under jamesp's threads.
Post by velodromed on Aug 23, 2023 11:42:42 GMT -5
Sorry to pull up an old post, but I’m really interested in your home made barrel. Where did you get the material for the barrel itself? I found HDPE pipe covers but couldn’t find anything like the barrel you show. I’d also love to see your home built tumbler. Is there a post showing how you built it? many thanks! Doug Doug, here's one. I know there are probably more if you search under jamesp 's threads. Thanks! I’ll check them out.
Post by Rockoonz on Aug 23, 2023 12:18:05 GMT -5
They are a piece of large PVC pipe with a cap glue welded to one end and a reducer fitting on the other. jamesp appears to use a short length of the pipe so the cap and reducer touch, I have seen others that are longer. Google MJR tumblers on ebay to see more examples of what I mean, MJR is ordering red colored fittings for theirs but essentially the same idea.
Post by velodromed on Aug 23, 2023 12:44:14 GMT -5
They are a piece of large PVC pipe with a cap glue welded to one end and a reducer fitting on the other. jamesp appears to use a short length of the pipe so the cap and reducer touch, I have seen others that are longer. Google MJR tumblers on ebay to see more examples of what I mean, MJR is ordering red colored fittings for theirs but essentially the same idea. Ok cool, thanks bud!!
Post by hummingbirdstones on Aug 23, 2023 17:41:44 GMT -5
Post by velodromed on Aug 23, 2023 17:45:56 GMT -5
All good! I’ve seen the post before and even responded for more info. Someday I’ll build my own tumbling set up and am researching heavily. Thanks again!
