oven
Member since January 2023
Post by oven on Jan 30, 2023 21:33:29 GMT -5
I bought an auction lot of tumbling media 20+ years ago and it came with a 1lb zip lock bag labeled Iron oxide polish. It is red-ish and feels like ~1200 grit. Any thoughts on using this instead of Tin oxide or aluminum oxide?
Post by Peruano on Jan 31, 2023 6:49:47 GMT -5
if you mix it with epoxy you can use it to fill holes, pits, or fractures in dark colored stones. Its color is capable of resisting removal from anything IIRC.
gemfeller
Member since June 2011
Post by gemfeller on Jan 31, 2023 11:46:12 GMT -5
I think it's mainly used as a metal polish, usually in bar form (jeweler's rouge).
Post by stefan on Feb 4, 2023 16:15:01 GMT -5
It will most likely stain any lighter colored rocks. I would use it with caution.
Wooferhound
Lortone QT66 and 3A
Member since December 2016
Post by Wooferhound on Feb 4, 2023 20:24:50 GMT -5
Could possibly be used to Stain The Cracks ?
