Post by stardiamond on Feb 12, 2023 17:52:48 GMT -5
This has been a really cold winter for my area. It will be weeks before I can resume grinding. When I can't grind, I shop and have marked up slabs for the trim saw. Today, I set up the saw. The two upper left will be for earrings that a customer requested.
Post by rockjunquie on Feb 13, 2023 6:53:04 GMT -5
Those should come out real nice! I was wondering where you got off to.
Post by jasoninsd on Feb 13, 2023 7:17:39 GMT -5
Those should come out real nice! I was wondering where you got off to. I was wondering the same thing... Nice to see you back stardiamond
Post by stardiamond on Feb 13, 2023 20:10:20 GMT -5
Post by liveoak on Feb 14, 2023 10:25:49 GMT -5
That Ray Mine Blue Dot Chrysocolla is something else. I look forward to seeing your cab stardiamond. Patty
Post by stardiamond on Feb 18, 2023 18:21:42 GMT -5
I worked on this one for a few minutes. I've done no other work for about a month because it was too cold. This one is tough because the soft blue and hard agate. When I get up to speed working on easier stuff, I'll finish this one. wet off the wheels.
adrian65
Member since February 2007
Post by adrian65 on Feb 18, 2023 23:54:42 GMT -5
So pity those blue spots are soft! It would had been a gorgeous cab.
Adrian
Post by stardiamond on Feb 19, 2023 15:01:07 GMT -5
I did a little work today. Tomorrow is supposed to warmer then the big chill arrives. I ground and dopped three trim saw preforms and worked on two that were previously dopped. OJ and Polka dot through 280 soft. Photographed wet off the wheels.
Post by stardiamond on Feb 20, 2023 16:08:31 GMT -5
Post by rockjunquie on Feb 21, 2023 8:50:41 GMT -5
Love that blue dot! Nice set!
Post by stardiamond on Mar 2, 2023 19:42:17 GMT -5
A customer wanted Blue Mountain earrings and I found a slab that had a good match.
Post by stardiamond on Mar 2, 2023 21:00:36 GMT -5
The blue dot bottom crumbled when I was scraping off the glue so I recut the bottom.
