keiths
Member since September 2021
Post by keiths on Apr 9, 2023 15:22:09 GMT -5
After 97 (24 hour) days, my UV10 will not run. It will hum but the motor will not run. I can spin it manually and the shaft on which the weight is mounted has some slop. I also have a UV18 that still works but it takes a lot to fill. UV10s, and replacement motors are unavailable (I would not be good at adapting a different motor).
Usually my work flow is to do stage 1 in rotaries, stages 2 and 3 in one of the two (now one) Ultravibes, and polish (for the rocks that will fit) in Lot-Os. My last batch was polished in the UV18. It did well, but the action, generally, is much slower than the UV10 was. Suggestions and/or thoughts about replacing with a Mini Sonic MT14? The idea of no moving parts is appealing.
Post by stefan on Apr 9, 2023 17:07:25 GMT -5
I have an MT-4. I got it for the very reason of the questionable motor quality we are seeing lately. I was all set to pull the trigger on a Lot-o when the motor problems reared its ugly head. Went with the mini sonic and never regretted it.
Post by manofglass on Apr 9, 2023 17:30:04 GMT -5
rockbrain
Member since January 2022
Post by rockbrain on Apr 10, 2023 19:16:09 GMT -5
These are cheap. It's also about 1/2 the size of what's being replaced. I may very well get one at some point but it's my understanding that they're loud and not made very well. I really like my MT4. Just remember it's a completely different action then the bowl type vibe tumbler. I wouldn't think it would work as well for slabs and flats as a bowl type. I'd personally much rather have one big bowl than 2 small ones, because I like to do larger material, but that's just me YMMV.
Post by manofglass on Apr 10, 2023 20:43:45 GMT -5
There cheap I get a wet shine from them I can polish stones up to 3-3/4" and slabs I polish both stone and glass
pebblesky
Member since September 2022
Post by pebblesky on Apr 10, 2023 22:06:19 GMT -5
Raytech TV5 is loud, but I don't have another vibratory to compare. The noise it produces is definitely not as pleasant as the noise from my Rebel 17.
Post by youp50 on Apr 12, 2023 15:56:09 GMT -5
For What Its Worth; the bowls are interchangeable. I have both bowls, don't recall if I bought the 10 or 18, I do interchange them as needed. The 10 gets much more use.
keiths
Post by keiths on Apr 16, 2023 18:14:33 GMT -5
The UV 10 bowl opening for the threaded rod will need to be drilled out larger to fit over the UV18 threaded rod. I didn't think about trying this. I have used the Mini bowel on the UV10 a few times.
