Mark K
Member since April 2012
Post by Mark K on May 13, 2023 22:33:06 GMT -5
I knew this rock was going to be insane the moment I laid eyes on it in the barrel at Tony's Quartzite spot. I have been trying to figure out how to cut it because it is like a half softball with a rough surface and no way to clamp it into the saw. I eventually screwed 2 2x4s together and used a stupid amount of wood glue to hold it. Waited well over a week for it to be completely dry and now it is in the saw and I am pleased so far. Every cut is way better then the last one. Even the end cut which is small is incredible.
Post by Pat on May 13, 2023 22:51:23 GMT -5
I’d like to see it!!😁
Mark K
Post by Mark K on May 13, 2023 23:11:32 GMT -5
You will. I think the feed just took a crap though.
Post by Rockoonz on May 13, 2023 23:42:13 GMT -5
Pics or it didn't happen...
Post by Rockoonz on May 13, 2023 23:47:41 GMT -5
Glue ups is about 3/4 of my cutting now, lots of the rough gets the end cut off then glued to 2x4 scraps with gorilla glue, need to get my super grinder set up so I can just grind enough flat for whatever dirction I want to cut.
Mark K
Post by Mark K on May 14, 2023 13:24:23 GMT -5
So I have this rock glued to the wood and I look at it to determine how I should place it in the saw and where the first cut should go. I see a tiny little natural notch in the perfect spot and mark it with a marker so I can't lose the spot. Once the saw is cleared up, I place the rock in the saw and line the blade and notch up perfectly. Everything is a go so far. Everything is tight and ready to go. I close the lid and hit the switch. There is the quiet sound of the blade gently cutting the rock. Music to our ears. It is a small cut. It does not take long. I figure that the first cut will not be as spectacular as the other end looks like it will be. The cut finishes and I open the saw and pull the first cut out. I am happy and a little bit surprised that it was this nice from the start. Here is the first cut. IMG_2271 by mrk525, on Flickr
Mark K
Post by Mark K on May 14, 2023 14:28:12 GMT -5
And then there was the next slice. At this point I decided that my hopes that this was going to be a superior rock were true. IMG_2272 by mrk525, on Flickr
khara
Member since September 2022
Post by khara on May 14, 2023 14:29:20 GMT -5
That is crazy.👍👍 Do you have a picture of the intact nodule?
Mark K
Post by Mark K on May 14, 2023 15:11:10 GMT -5
nope
Post by rockjunquie on May 14, 2023 16:51:47 GMT -5
Wow! That's pretty damn sweet!
Mark K
Post by Mark K on May 14, 2023 18:03:20 GMT -5
Mark K
Post by Mark K on May 14, 2023 18:04:31 GMT -5
Mark K
Post by Mark K on May 14, 2023 18:04:58 GMT -5
Mark K
Post by Mark K on May 14, 2023 18:05:48 GMT -5
Post by hummingbirdstones on May 14, 2023 18:07:59 GMT -5
Talk about winner, winner chicken dinner! That's gorgeous.
gunsil
Member since January 2023
Post by gunsil on May 14, 2023 19:37:54 GMT -5
Insane!
Post by liveoak on May 15, 2023 5:50:45 GMT -5
After those slices I think you probably need to quit- no topping that. Can't wait to see what you do with them.
Patty
Post by Peruano on May 15, 2023 6:23:09 GMT -5
You owe Tony more money based on how much enjoyment you are getting out of the rock.
AzRockGeek
Member since September 2016
Post by AzRockGeek on May 15, 2023 7:40:13 GMT -5
Cut a nice thin slice, about half as thick. See if you have turtle back or iris, looks like you should see some turtle back.
chris1956
Member since July 2022
Post by chris1956 on May 15, 2023 8:06:23 GMT -5
Incredible slabs!
