Post by stardiamond on Jun 7, 2023 14:27:23 GMT -5
Post by realrockhound on Jun 7, 2023 16:31:20 GMT -5
Triangles are my favorite shape. 3 points where two lines meet.
Post by Pat on Jun 7, 2023 17:34:22 GMT -5
rocknewb101
Member since October 2022
Post by rocknewb101 on Jun 8, 2023 6:52:19 GMT -5
Nice! Is there something different you need to do when cabbing a shape like a triangle? I haven't ventured past circle or oval yet
Post by realrockhound on Jun 8, 2023 9:42:13 GMT -5
Nice! Is there something different you need to do when cabbing a shape like a triangle? I haven't ventured past circle or oval yet Key to a good triangle is to keep your bevels equal to each other. Then when you begin to dome, your cab won’t look lopsided. It’s really like that for most stones.
Post by stardiamond on Jun 8, 2023 11:05:08 GMT -5
I have found that the same technique works on different shapes. Material needs to be removed at the beginning and for triangles I grind straight to the girdle line on each side and then rock between two adjacent girdle lines for all three sets of adjacent lines. That produces three ridges. I grind the ridges until they match and then work circular until the highest point is in the center. A person could do the entire process working circular, rotating the stone above the girdle line until it is ground to the girdle line.
Post by stardiamond on Jun 8, 2023 13:07:34 GMT -5
Post by stardiamond on Jun 8, 2023 13:35:59 GMT -5
Post by liveoak on Jun 9, 2023 6:34:10 GMT -5
A nice ending
Patty
adrian65
Member since February 2007
Post by adrian65 on Jun 10, 2023 22:29:13 GMT -5
I like the contrast between the preforms and the finished cabs. Great enhancement, beautiful result.
Adrian
