rockbrain
Member since January 2022
Post by rockbrain on Jun 11, 2023 22:40:00 GMT -5
This is my first set and my first earrings. Not my first groove wrap but I did my first one today and this is my second, third and fourth. Unfortunately, I ended up with a small chip at the top of the pendant.
ashley
Member since February 2023
Post by ashley on Jun 11, 2023 22:40:53 GMT -5
Those look amazing Gary! Awesome job!
Post by tims on Jun 11, 2023 23:55:41 GMT -5
Very beautiful.
Post by liveoak on Jun 12, 2023 6:00:00 GMT -5
Nice ones & an excellent idea.
Ya know, I never considered groove wrapping earrings- what a terrific idea.
Thank you for that !
Patty
Post by rockjunquie on Jun 12, 2023 6:08:41 GMT -5
Very nice!
Post by Lazy Perfectionist on Jun 12, 2023 10:12:07 GMT -5
They look fabulous! I'd hire you.
chris1956
Member since July 2022
Post by chris1956 on Jun 12, 2023 10:39:51 GMT -5
Those look great!
Post by susand24224 on Jun 12, 2023 16:29:57 GMT -5
Very nice! You picked the perfect cabs for your set, and with only one chip on your 2nd, 3rd and 4th, they are amazing.
rockbrain
Post by rockbrain on Jun 12, 2023 21:46:41 GMT -5
Those look amazing Gary! Awesome job! Thanks I appreciate it ashleyThank you! Nice ones & an excellent idea.
Patty
Thanks Patty, I don't think I want to try a regular wrap on this small of cab! Very nice! Thank you Tela. They look fabulous! I'd hire you. Thanks, I appreciate that. Thanks Chris, love the stones in your avatar. Very nice! You picked the perfect cabs for your set, and with only one chip on your 2nd, 3rd and 4th, they are amazing. Thanks Susan! I guess I did 2 other first, so I lied. This is actually 3rd, 4th and 5th!
rocknewb101
Member since October 2022
Post by rocknewb101 on Jun 13, 2023 8:42:55 GMT -5
Very nice! What a beautiful set. Can't even really see the chip - I had to look hard to find it. What do you use to cut the groove?
Post by jasoninsd on Jun 13, 2023 21:47:31 GMT -5
The cabs and polish are astounding. What caught my eye with the set was your choice of pattern placement...your positioning of the fortification patterning was fantastic! Way to go!
*I've chipped a couple cabs doing some groove wraps when I was working the wire in the groove. I've decided I'm only going to do groove wraps if they're preplanned...meaning I'll make sure the girdle is a little thicker on any of the ones I'm going to groove wrap...it keeps them from chipping as easily.
michiganpebbler
Member since April 2023
Post by michiganpebbler on Jun 14, 2023 10:26:39 GMT -5
Beautiful!
rockbrain
Post by rockbrain on Jun 14, 2023 19:00:14 GMT -5
Very nice! What a beautiful set. Can't even really see the chip - I had to look hard to find it. What do you use to cut the groove? Thanks! I use a stained glass grinder. It's got a flat top and the shaft sticks straight up through it. There's a thin round grinding wheel that's basically a diamond incrusted horizontal disc. I made a fence to control the depth of the groove. The disc can be moved up and down the shaft so the groove is in the right place on the stone. The cabs and polish are astounding. What caught my eye with the set was your choice of pattern placement...your positioning of the fortification patterning was fantastic! Way to go! *I've chipped a couple cabs doing some groove wraps when I was working the wire in the groove. I've decided I'm only going to do groove wraps if they're preplanned...meaning I'll make sure the girdle is a little thicker on any of the ones I'm going to groove wrap...it keeps them from chipping as easily. Thanks Jason. There was kind of a repeating pattern along the edge of the cap so I was able to match the earrings pretty well. I chipped this one while grinding so I had to reshape the top and then go back and cut the groove in the top again. It's a lot easier to do when the cab is still flat! Thank you michiganpebbler I appreciate it.
rockbrain
Post by rockbrain on Jun 14, 2023 19:08:45 GMT -5
rocknewb101 Peta this is the grinder. It doesn't look like it but the little backstop on the bottom is set to let it grind about the depth of a 20g square wire.
gunsil
Member since January 2023
Post by gunsil on Jun 15, 2023 9:51:00 GMT -5
Very nice, I like the hammered ear wires, good job!
rocknewb101
Post by rocknewb101 on Jun 15, 2023 11:03:41 GMT -5
Ohh! Thanks, rockbrain for sharing that! Very interesting.
texhex
Rocks 10 - TexHex 2
Member since August 2023
Post by texhex on Aug 19, 2023 19:56:23 GMT -5
Amazing for a first set...... Heck, that is amazing for even a veteran specialist.
