skmcconnell361
Member since August 2023
Post by skmcconnell361 on Aug 12, 2023 17:35:12 GMT -5
Now that I have my replacement tumbler I also have two batches of Gem Foam. From what I have read here these seem pretty much useless and a waste of time. I was wondering if anyone actually gotten decent results with these and what did you do different from the instructions?
ashley
Member since February 2023
Post by ashley on Aug 12, 2023 19:23:46 GMT -5
I threw mine away didn’t want to waste the thing.
Post by Mel on Aug 14, 2023 23:01:40 GMT -5
Never heard of it, been tumbling around a decade. Grit, water, rocks, done.
rocknewb101
Member since October 2022
Post by rocknewb101 on Aug 15, 2023 8:03:09 GMT -5
I tried it the first couple of batches and it did absolutely nothing so I got rid of it. It's gimmicky, I think...
waterboysh
Member since April 2021
Post by waterboysh on Aug 15, 2023 8:33:07 GMT -5
Timestamp 24:39 in case it doesn't start there like it should.
michiganpebbler
Member since April 2023
Post by michiganpebbler on Aug 15, 2023 15:32:17 GMT -5
I threw mine away didn’t want to waste the thing. Same.
skmcconnell361
Post by skmcconnell361 on Aug 15, 2023 17:58:02 GMT -5
waterboysh, yes I have seen that video and his Tutorial series. And have modified the process with the advice Rob gives in the tutorial series. So now I am not expecting good results with National Geographic grit. Wish I saw these videos before I bought more Nat Geo grit. but I will use what I got then start getting my Grit from the Rock Shed. I also got the book "Modern Rock Tumbling" by Steve Hart. In that book Steve mentions a 5 step process, so I am hoping that some AO Polish from the Rock Shed for step 5 will salvage my first batch of rocks (1/2 Pound the came with the tumbler). I started out with the National Geographic Hobby Tumbler and later bought the Harbor Freight dual barrel tumbler. I really do not think the Nat Geo hobby tumbler is a bad tumbler, just as Rob said in his video bad polish on Nat Geo's part.
Wooferhound
Lortone QT66 and 3A
Member since December 2016
Post by Wooferhound on Aug 17, 2023 15:17:35 GMT -5
I ended up with a 5 step process using . . . 30 220 600 1000 14000 rock shed Very pleased with the results and will continue this method.
skmcconnell361
Post by skmcconnell361 on Aug 17, 2023 17:11:11 GMT -5
As Juggerguy (Rob) said in the video National Geographic Grit is good grit, but Step 4 is not a polish. Silica Carbrite is a poor choice for polish especially 1000 grit. You just will not get a shine with that stuff. I knew that before I started tumbling rocks. As soon as Rob said that step 4 was 1000 grit SC I went to the Rock Shed web page and ordered 3 lb Aluminum Oxide Polish. The step 4 grit should ok as a pre polish. So I will be using a 5 step process from here on out also.
dillonf
Hounding and tumbling
Member since February 2022
Post by dillonf on Aug 17, 2023 20:11:38 GMT -5
I've incorporated a 1000 grit pre-polish into my cycles. I don't like the jump from 500 to polish.
