Post by stardiamond on Aug 23, 2023 12:30:55 GMT -5
I bought a parcel of Tahoma rough. Most of it is too thin to slab across the seam. Cutting with the seam, requires thick bands of material otherwise the slabs are not nice. I picked the pieces with the most promise and glued them to boards on Sunday. Today, I found out what is there.
Post by jasoninsd on Aug 23, 2023 15:18:12 GMT -5
Post by stardiamond on Aug 23, 2023 17:13:35 GMT -5
I started with the biggest piece. My plan was to remove as little material as possible, so only faced the highest part. Next largest piece. Next. Last piece. On the other pieces I tried to make a precise cut. I had no clear information, so went for the middle. I applied my fracture detecting algorithm. and ended up with this: The rest of the work will be done with the trim saw and that is another day.
Post by jasoninsd on Aug 23, 2023 20:47:28 GMT -5
I applied my fracture detecting algorithm. This was hilarious!!
ashley
Member since February 2023
Post by ashley on Aug 23, 2023 21:01:45 GMT -5
The second one is a real beauty!
Post by stardiamond on Aug 23, 2023 21:12:42 GMT -5
This only step 1. Step 2 is trimming and step 3 is the preforms. I know this isn't Sutter's Mill, but there is more here to be discovered.
Jason, given a large slab with a lot of visible fractures, I like to slam the slab into my worktable. No decision making about partially healed and invisible fractures. Slabs don't fracture in a straight line.
