Post by realrockhound on Aug 26, 2023 19:19:16 GMT -5
Went out at 5:30 am this morning to make a long hike into a spot where i've been digging some plume agate I refer to as Jackhammer plume. Looking West to the old Carey digs. You can see them in the background were the grounds been cut. But not close to where I was headed. What this plume looks like in the rough. What it looks like cut. Some of it has blue moss inclusion in it. See in bottom of this piece. Dont mind the spit. Anyways... thats all. I came out with a good amount (not pictured). Just wanted to share a piece I found and cut.
dillonf
Hounding and tumbling
Member since February 2022
Post by dillonf on Aug 26, 2023 20:21:17 GMT -5
Really nice stuff! Looks like a beautiful hike. Must be tough hiking out loaded down with rock.
Post by realrockhound on Aug 26, 2023 20:26:41 GMT -5
Really nice stuff! Looks like a beautiful hike. Must be tough hiking out loaded down with rock. It can be. I’ll normally limit myself to a certain amount depending on the terrain I have to hike. It’s steep where I went.
ashley
Member since February 2023
Post by ashley on Aug 26, 2023 20:52:28 GMT -5
That is some really beautiful stuff! And awesome location.
Post by realrockhound on Aug 26, 2023 20:58:20 GMT -5
That is some really beautiful stuff! And awesome location. Thanks. Most all the area out here looks like that. Juniper trees everywhere.
Post by jasoninsd on Aug 26, 2023 21:13:19 GMT -5
Is that the same material you sent me quite some time ago and I worked??
Post by realrockhound on Aug 26, 2023 21:19:55 GMT -5
Is that the same material you sent me quite some time ago and I worked?? Affirmative. That was in the early exploration phase. I had just cut some and had it lying around. That was before I even cabbed. Sent that random slab just to see how it would cab up. I’ll send you some of this if you want.
Post by jasoninsd on Aug 26, 2023 21:24:17 GMT -5
Is that the same material you sent me quite some time ago and I worked?? Affirmative. That was in the early exploration phase. I had just cut some and had it lying around. That was before I even cabbed. Sent that random slab just to see how it would cab up. I’ll send you some of this if you want. I thought it looked like it was. You know what you should do? I wasn't doing doublets back then. I wonder if cut thin if it would make a good doublet with a white background material...
chris1956
Member since July 2022
Post by chris1956 on Aug 26, 2023 22:02:21 GMT -5
The view and the rocks are both great looking!
Post by realrockhound on Aug 26, 2023 22:18:40 GMT -5
Affirmative. That was in the early exploration phase. I had just cut some and had it lying around. That was before I even cabbed. Sent that random slab just to see how it would cab up. I’ll send you some of this if you want. I thought it looked like it was. You know what you should do? I wasn't doing doublets back then. I wonder if cut thin if it would make a good doublet with a white background material... Funny, was just thinking that today.
Post by realrockhound on Aug 26, 2023 22:19:18 GMT -5
The view and the rocks are both great looking! Thank you.
Post by rockjunquie on Aug 27, 2023 7:09:35 GMT -5
Ooooooo.... lotsa possibility!
