wargrafix
Member since June 2023
Post by wargrafix on Sept 10, 2023 6:19:14 GMT -5
I am sure I asked this before, but couldn't track back the answer.
While I would like to buy a lap saw, I will have to stick with the tile saw for now. The saw it comes with is thick and I was surprised how much material it ate.
I have seen thinner tile saw blades, but I am concerned about safety. What direction should I look to?
Post by liveoak on Sept 10, 2023 6:39:13 GMT -5
Here's the 7" blade I purchased for my tile saw. It's thinner & seems to work OK ( and is cheap enough).
180mm 7" Super thin saw blade
Patty
wargrafix
Post by wargrafix on Sept 10, 2023 9:26:36 GMT -5
It's a lap disc, would that be safe on a tile saw?
Post by Rockoonz on Sept 10, 2023 9:58:35 GMT -5
If you are wanting to use it as a flat lap to grind with, there should be a thicker master lap behind the lap to keep it rigid, so there would have to be enough threads on the arbor to fit all that, as well as modifying the slot in the saw top. The wider slot will cause problems when using it as a saw. Laps are capable of the high speeds of a lap disc, but centrifugal force will sling almost all the water off, so dust and short lap life will be an issue.
Post by liveoak on Sept 10, 2023 10:14:26 GMT -5
It's a lap disc, would that be safe on a tile saw? NO, it's a saw blade, with only diamond around the rim, NOT a flat lap. It's a 7" sintered diamond saw blade from Hong Kong, no less.
They describe it as "segmented" but it's NOT, it's a continuous rim diamond SAW BLADE Works fine on my 7" cheap tile saw Patty
Post by Rockoonz on Sept 10, 2023 10:46:51 GMT -5
liveoak never tried a blade from lau*** but been buying carving burrs and core drills from THK for years, I gather you like the blades?
Post by liveoak on Sept 10, 2023 11:00:53 GMT -5
It's been holding up pretty good Lee, Rockoonz - even cut some thin intarsia strips pretty nicely. So it cuts smoothly enough. Patty
JR8675309
Member since August 2019
Post by JR8675309 on Sept 10, 2023 11:17:35 GMT -5
I have a "hot dog" blade I like on tile saw. I use a KN cheapie on my 20" and love it.
wargrafix
Post by wargrafix on Sept 10, 2023 13:15:59 GMT -5
Next year I will be buying more geodes and my concern was thinner blades meeting more solid geodes and it being safe
Post by Rockoonz on Sept 10, 2023 21:41:38 GMT -5
wargrafix there may be a small risk to the operator when hand cutting on a tile saw, but if the rock isn't lifted off the table and especially if you pull it through from the back of the saw it's pretty small, a lot less than most power tools. Risk to thin blades getting bent is a whole nother issue, especially with a round rock that can accidentally turned and bind up and bend the blade.
wargrafix
Post by wargrafix on Sept 11, 2023 8:12:06 GMT -5
Thank you for your response. Everyone has been amazing. I watched a fair amount of videos and realized that from the back is far safer and smarter. I took the appropriate protections, gloves and pace protection. Cutting on the saw was actually really good and having used power tools in the past, its pretty easy.
I was not prepared how much material the saw blade ate. How thin a tile blade can go without being a problem for a solid geode?
wargrafix
Post by wargrafix on Sept 11, 2023 8:14:20 GMT -5
Patty
How wide is this compared to the default sold by skil or similar blades?
Post by liveoak on Sept 11, 2023 8:31:55 GMT -5
The blade on e-bay is Thickness : 1.3mm
It's much thinner than what the tile saw came with. Not sure the specs on other blades. I'm sure you can easily look up the specs on any blade.
Patty
Post by parfive on Sept 11, 2023 15:35:17 GMT -5
A 1.3mm rim on a seven-inch blade might be considered thin in the tile business but it certainly isn’t in our neck o’ the woods.
I run the same size (0.050 of the King’s inch*) on a 14” saw w/no problems.
* derived from the Latin uncia, one-twelfth of the Roman foot. Once defined as three grains of barley, dry and round, placed end to end, lengthwise, it’s now derived from the distance light travels in a vacuum in a period of time based on the frequency of a Caesium-133 atom.
wargrafix
Post by wargrafix on Sept 11, 2023 19:03:41 GMT -5
While I know I still have time before I buy next set of agates and geodes, Is there one on amazon that I can order?
wargrafix
Post by wargrafix on Nov 26, 2023 14:58:25 GMT -5
A bump.
What's a recommended thin 7" tile saw for cutting geodes?
Amazon links preferred
hypodactylus
Member since July 2021
Post by hypodactylus on Nov 26, 2023 17:54:11 GMT -5
wargrafix
Post by wargrafix on Nov 26, 2023 18:00:09 GMT -5
Those are great recommendations. If I want to go continuous blade?
So. Many. Choice
Post by stardiamond on Nov 26, 2023 22:21:08 GMT -5
Lapidary is not a cheap hobby. In the long run it is wise to invest in better equipment. When I bought my Genie there was a deal for the trim saw attachment for almost free. The saw uses an 8 inch .032 MK303 blade. For trimming it is fine but when I used it for slabbing it ate blades. I bought a 10 inch slab saw the has about the same kerf, vise, power feed and cuts with oil. A blade lasts much longer.
wargrafix
Post by wargrafix on Nov 27, 2023 8:02:21 GMT -5
I am more interested in cutting geodes and agates. A lap saw is a bit pricey for me. Right now I am sticking with a tike saw. The thin blade is what I am looking at.
The supplied blade eats material
