First off, thank you for the auto-embed image plugin! That makes it much easier to share (at least for the Imgurians), and is greatly appreciated.
This is probably a bit off topic for the forum as it's in relation to Tapatalk which I realize you have no control over. But I'm hoping you might have some advice to share given your expertise and experience.
In the post linked above, I noticed it worked great when using both the desktop and mobile websites, either as a pasted URL or an embedded image. In Tapatalk, for the pasted URL it just shows up as a URL, which I would expect. So in an attempt to make it easier for Tapatalk users to view, I tried manually inserting IMG tags. However, I get the broken image thumbnail.
I have a couple different versions of the file I've tried to create. A 4K HEVC (h265) MP4, and a 720p h264 MP4 which I tried for compatibility's sake. The former might be a tall ask as it's a newer format, but the latter has been around for over a decade and I'd expect that to work no problem.
As an example I'll create four posts below; the first two with the links pasted, big then small, and the latter two with IMG embeds, big then small.
Last Edit: Sept 12, 2023 9:35:04 GMT -5 by iamchris
Looks like the 4K HEVC video was a mistake. My fans are going into overdrive! 720p looks nearly as good when limited to 50% width and has the bonus of being smooth.
Not sure there's a workaround for this - it appears my previously posted Imgur videos also do the same thing. Looks like this might be a Tapatalk limitation that I can't get around, but if you've got any advice Tommy I'm all ears! Thanks again.
I love that the auto-embed turns off autoplay, and still provide the link for Tapatalk users to click. I think that will be the way to go at least for now.
Last Edit: Sept 12, 2023 9:35:52 GMT -5 by iamchris
Hi iamchris this is probably not the help you were wishing for but I have no idea how to get around the incompatible video type. My only experience with tapatalk was a few years ago and was not a good one so I deleted it. Maybe try searching the webs - or poke around in the proboards embedding mod and see if the situation has been addressed?
I did a good amount of searching before creating this post and wasn't able to even find anyone reporting the same issue. Maybe it's a bug I should report to them once I get back from Alberta.
Thanks for checking out the question and for your response, Tommy!
ThomasT: The rare Double brood of Cicadas coming out now... last time this occurred Thomas Jefferson was President...
May 7, 2024 17:42:04 GMT -5
ThomasT: Cicadas 13- and 17-year emergence cycles align only once every 221 years... much rarer than a solar Eclipse. Next event will be in the year 2245 AD. Woohoo
May 7, 2024 17:55:50 GMT -5
ThomasT: Buy your tickets now... once in a lifetime
May 7, 2024 20:16:09 GMT -5
Wooferhound: why aren't they making any noise
May 8, 2024 12:11:59 GMT -5
ThomasT: Too early yet... I'm sure they will get pretty loud this summer.
May 8, 2024 13:14:48 GMT -5
amygdule: The crispy fried Cicadas don't make any noise until you chew on them
May 8, 2024 14:10:18 GMT -5
Wooferhound: The last person that quit or was fired will be held responsible for everything that goes wrong -- until the next person quits or is fired.
May 8, 2024 16:22:09 GMT -5
liveats14rocks: the fox has entered the glade
May 8, 2024 17:46:23 GMT -5
RickB: Welcome to the board. You are just in time for appetizers
May 8, 2024 19:25:39 GMT -5
Wooferhound: it's Cicada me if its Cicada you
May 8, 2024 20:40:29 GMT -5
1dave: To fix any body problem Just place a spoon on it and tap with another spoon. The WEB has spoken!
May 8, 2024 21:54:09 GMT -5
Wooferhound: I Like Spooning
May 9, 2024 5:42:33 GMT -5
thestripedone: I've been using ceridium oxide for my 4th step of polishing. I was wondering if there is a 5th step for a super polish
May 10, 2024 17:20:10 GMT -5
amygdule: Silicon Carbide SiC grind in Rotary then Aluminum Oxide AO polish in a vibe...
May 10, 2024 17:37:12 GMT -5
