hypodactylus
Member since July 2021
Post by hypodactylus on Oct 11, 2023 10:58:31 GMT -5
I measure the barrel RPMs on my tumblers after I buy them. I thought I would share the information I have, in case someone finds it useful.
Hopefully others will add to this thread. It might be useful to add a note if the reading was on a new or well used tumbler.
The following values are all under load (barrels filled with rock, water, grit, etc).
Lortone 3A Tumbler (new) 63 rpm
Lortone 3A Tumbler (after a year or two) 58 rpm
Highland Park 3lb Tumbler (new) 38 rpm
Lortone 45C Tumbler (new) 41 rpm
Lortone QT12 Tumbler (new) 34 rpm
Lortone QT12 Tumbler (after a year or so) 33 rpm
National Geographic Pro 3lb Tumbler Speed 1 = 86 rpm Speed 2 = 108 rpm Speed 3 = 123 rpm
Post by parfive on Oct 11, 2023 13:55:10 GMT -5
All 3 lb barrels, Thumler's, at age 3 Model Ts - fast, 50 - 55 rpm - for coarse grind 60/90 Model AR-2 - slower, 32 rpm - for anything else
adam5
Member since August 2023
Post by adam5 on Oct 11, 2023 17:04:19 GMT -5
Chicago Electric dual drum #1 (2.5 months old): 46 rpm CE dual drum #2 (2 months): 49 rpm Rebel 17 hi-speed version (1 month): 39 rpm Lortone QT66 or equivalent (bought used): 28 rpm Nat Geo Hobby (1.5 months) @ 4.5 volts: 41 rpm Nat Geo Hobby @ 12 volts: 108 rpm
Post by jasoninsd on Oct 11, 2023 18:19:36 GMT -5
Jason's tumblers: Zero RPMs...because I haven't had them running in forever! LOL Great idea for a thread hypodactylus!!
dillonf
Hounding and tumbling
Member since February 2022
Post by dillonf on Oct 11, 2023 21:27:37 GMT -5
This is great information! Thank You.
