chris1956
Member since July 2022
Member is Online
Post by chris1956 on Oct 14, 2023 19:59:40 GMT -5
OK, you all were right and I was wrong. I previously poo pooed trying to get more oil from the sludge once you decant the oil off of it. I havne't cleaned my 16-inch saw too many times but in the past I just kept decanting the oil off the top until I wasn't getting much more and then disposed of the sludge. So last time I did the same thing and got to the point where I wasn't getting too much more oil to decant. I then put all of the sludge in a brown paper bag and let it filter for 2 weeks. At the end of the 2 weeks I got one and a half quarts off of the decanted sludge. How could I have doubted you? Good thing someone posted about the brown bag method! Thanks!
rockbrain
Member since January 2022
Member is Online
Post by rockbrain on Oct 14, 2023 20:23:04 GMT -5
I'm still amazed at how clean it comes out after running through the bag. Glad you had success with it.
Post by jasoninsd on Oct 14, 2023 20:59:45 GMT -5
chris1956 - We all make mistakes. Just take a deep breath...it'll be okay! LOL
Post by broseph82 on Oct 19, 2023 10:16:43 GMT -5
OK, you all were right and I was wrong. I previously poo pooed trying to get more oil from the sludge once you decant the oil off of it. I havne't cleaned my 16-inch saw too many times but in the past I just kept decanting the oil off the top until I wasn't getting much more and then disposed of the sludge. So last time I did the same thing and got to the point where I wasn't getting too much more oil to decant. I then put all of the sludge in a brown paper bag and let it filter for 2 weeks. At the end of the 2 weeks I got one and a half quarts off of the decanted sludge. How could I have doubted you? Good thing someone posted about the brown bag method! Thanks! If you want it to come out quicker one use one bag. I've done the double bag method and it seems to take so much longer
Post by parfive on Oct 19, 2023 11:29:35 GMT -5
One bag’s never failed me.
Two-bag job is a whole ‘nother ballgame.
Mark K
Member since April 2012
Post by Mark K on Oct 19, 2023 16:35:25 GMT -5
I made a video about it. It does work. It is slow but effective. The bag you use matters too. A few weeks back I playe4d a game with how long it would take. I chose poorly when it came to bags because the bag I grabbed was so fine that it took about 10 times as long to work as normal. That slime is still in the bag and it is almost spent. Next time I will use the bags I usually use. They let the 1,000,000 mesh stuff through but that is ok with me.
chris1956
Member is Online
Post by chris1956 on Oct 19, 2023 16:35:42 GMT -5
OK, you all were right and I was wrong. I previously poo pooed trying to get more oil from the sludge once you decant the oil off of it. I havne't cleaned my 16-inch saw too many times but in the past I just kept decanting the oil off the top until I wasn't getting much more and then disposed of the sludge. So last time I did the same thing and got to the point where I wasn't getting too much more oil to decant. I then put all of the sludge in a brown paper bag and let it filter for 2 weeks. At the end of the 2 weeks I got one and a half quarts off of the decanted sludge. How could I have doubted you? Good thing someone posted about the brown bag method! Thanks! If you want it to come out quicker one use one bag. I've done the double bag method and it seems to take so much longer Thanks. I used a single bag but it was a heavy duty shopping bag. Will try regular bag next time.
Post by pauls on Oct 19, 2023 18:04:46 GMT -5
I just use a pillowcase or flannelette shirt, it traps 99.9% of the gunk. We don't have big brown paper shopping bags in Australia.
Post by RWA3006 on Oct 19, 2023 18:52:26 GMT -5
I just use one bag. Works fine. It is amazing how crystal clear it comes out.
lapidarycentral
(Brian Rhode) LapidaryCentral.com - Fueling your Lapidary Addiction.
Member since August 2021
Post by lapidarycentral on Oct 20, 2023 17:26:58 GMT -5
Yep, we have a setup we did with a 55 gallon drum with a suspended bucket. Put the bag in the bucket, and clean oil drops into the rain barrel with a spigot. Works wonders and saves us a lot of money!
Post by broseph82 on Oct 20, 2023 21:29:17 GMT -5
If you want it to come out quicker one use one bag. I've done the double bag method and it seems to take so much longer Thanks. I used a single bag but it was a heavy duty shopping bag. Will try regular bag next time. WholeFoods bags have been the ones I've been using for years.
markymark
Member since November 2015
Post by markymark on Oct 21, 2023 16:47:29 GMT -5
I don't filter anything, I just pour everything into a 5 gal bucket and let it set for a couple weeks and ladle off the top, easy peasy
Post by RWA3006 on Oct 21, 2023 18:03:51 GMT -5
I don't filter anything, I just pour everything into a 5 gal bucket and let it set for a couple weeks and ladle off the top, easy peasy I've done this and it works well. After doing it I'll often filter the remaining thick sludge just to salvage a little more oil.
