rocknewb101
Member since October 2022
Post by rocknewb101 on Oct 30, 2023 11:47:01 GMT -5
So I have a few small agates that I'd like to just face polish and other than a small lip where the bottom cut occurred, it's flat as flat can be and really not any saw marks that I can tell. So do I need to go back to the hard wheels just to have to work out the scratches? Can I just start with the 280 soft and work from there? When I see the scratches the 280 can smooth, this should be a piece of cake, right? Thanks!
Post by rmf on Oct 30, 2023 17:31:15 GMT -5
I would try the 280 soft and see how it goes. If it needs a 220 you will notice it soon enough.
rocknewb101
Post by rocknewb101 on Oct 30, 2023 18:12:48 GMT -5
I would try the 280 soft and see how it goes. If it needs a 220 you will notice it soon enough. Fair enough! I will give it a go and see what happens. Thanks, rmf!
Post by jasoninsd on Oct 30, 2023 20:46:49 GMT -5
khara
Member since September 2022
Post by khara on Oct 30, 2023 21:17:56 GMT -5
I have often wondered this same thing. It seems some slabs have nearly no saw marks and I wonder what wheel is a best match. I like to give the backs of cabs at least a little matte polish. I usually start with 280 soft and that seems to please me enough but I haven’t gotten any more scientific than that.
Post by parfive on Oct 30, 2023 23:54:59 GMT -5
Lap it for a few minutes on a piece of glass and you’ll see if it’s flat as flat can be.
A pinch of 500 will do.
[edit]
I see you have a slant cabber, that’ll inform without the elbow grease.
rocknewb101
Post by rocknewb101 on Oct 31, 2023 7:03:18 GMT -5
I have often wondered this same thing. It seems some slabs have nearly no saw marks and I wonder what wheel is a best match. I like to give the backs of cabs at least a little matte polish. I usually start with 280 soft and that seems to please me enough but I haven’t gotten any more scientific than that. I'll give it a go and see what happens. Good thing is I can always go back if needed. I do have a flat lap on the cabber that I think is 280 perhaps...might even try that first and then the 280 soft. Just didn't want to create unneeded scratching (it's my nemesis ha!). Thanks! Lap it for a few minutes on a piece of glass and you’ll see if it’s flat as flat can be. A pinch of 500 will do. [edit] I see you have a slant cabber, that’ll inform without the elbow grease. I do still have the slant lap, but I'm not using it since I got the cab king. But the CK also has a flat lap on the side I forgot about. I leave for a 2wk vacation on Saturday so will put this on hold until I return. Thanks!!
dshanpnw
Member since December 2020
Post by dshanpnw on Oct 31, 2023 10:49:19 GMT -5
Do you have a #360 disc on the end of the Cabking? I would use that then go to the 280.
gunsil
Member since January 2023
Post by gunsil on Oct 31, 2023 20:44:50 GMT -5
I agree with those who suggest using the slant cabber for polishing flats. Hard to get a flat surface polished on a wheel rather than a lap.
Post by liveoak on Nov 1, 2023 6:25:47 GMT -5
Hope you have a great vacation
Patty
Post by roy on Nov 1, 2023 11:49:01 GMT -5
Lap it for a few minutes on a piece of glass and you’ll see if it’s flat as flat can be. A pinch of 500 will do. [edit] I see you have a slant cabber, that’ll inform without the elbow grease. lol thats old school i like it
rocknewb101
Post by rocknewb101 on Nov 1, 2023 13:53:13 GMT -5
Do you have a #360 disc on the end of the Cabking? I would use that then go to the 280. I think that's what it is. Whatever flat lap came with the CK, I have. That'll work well, I think. Thanks!
rocknewb101
Post by rocknewb101 on Nov 1, 2023 13:55:11 GMT -5
I agree with those who suggest using the slant cabber for polishing flats. Hard to get a flat surface polished on a wheel rather than a lap. I watch Agate Dad on TikTok polish small agates like this on his wheels so I figured why the heck not try. This agate half is only about an inch and a hair big. i wish I had the extra room to keep all of the equipment set up...
rocknewb101
Post by rocknewb101 on Nov 1, 2023 13:55:41 GMT -5
Patty
Thank you!!!
Post by Mel on Nov 1, 2023 14:49:15 GMT -5
I'd go at 280, worst case it will show you if you need the 220! Best case, it saves you some time.
wargrafix
Member since June 2023
Post by wargrafix on Nov 2, 2023 8:33:50 GMT -5
I have gotten good at hand polish. One day i will get a cabber I usually start with 60 grit sandpaper all the way up to 2500 grit Rough side other side after final polish
Post by stardiamond on Nov 2, 2023 16:26:29 GMT -5
