Post by Mel on Nov 20, 2023 17:52:51 GMT -5
Awhile ago I got a beautiful dulcote agate piece (not my photo but my material is nearly identical). I've never seen anything like it and only discovered what it was when I saw the Sept. 1977 issue of Lapidary Journal featuring Dulcote geodes on the cover. I tried googling but there doesn't seem to be much information about working with Dulcote material at all and the mine they came from has been closed for a long time. I ran it on the vibra lap with cerium for about 16 hours and it's got a dull shine to it but I'm wondering if it could be better. Normally I'd mess around but I only have the one piece of material. Would it maybe be worth redoing the agate on the flat lap with tin oxide? Diamond paste maybe?
Post by rmf on Nov 20, 2023 18:39:02 GMT -5
Dulcote Agate has calcite with the agate. I have a piece in the basement and just looked at it last week and mused whether I should slab and cab one. My guess is will only take a so so polish because of the calcite. May have to add oxalic acid to the polish to get the calcite to polish better.
Post by Mel on Dec 2, 2023 10:16:40 GMT -5
Dulcote Agate has calcite with the agate. I have a piece in the basement and just looked at it last week and mused whether I should slab and cab one. My guess is will only take a so so polish because of the calcite. May have to add oxalic acid to the polish to get the calcite to polish better. Thanks rmf! I was wondering how I could get it good and shiny; it’s such beautiful material with all the banding and swirls. I’ve never heard of adding oxalic acid; can you give me more details??
Post by rmf on Dec 4, 2023 12:02:01 GMT -5
Dulcote Agate has calcite with the agate. I have a piece in the basement and just looked at it last week and mused whether I should slab and cab one. My guess is will only take a so so polish because of the calcite. May have to add oxalic acid to the polish to get the calcite to polish better. Thanks rmf ! I was wondering how I could get it good and shiny; it’s such beautiful material with all the banding and swirls. I’ve never heard of adding oxalic acid; can you give me more details?? I knew a guy that did marble years ago. He hand polished marble with a block of felt and tin oxide with some oxalic acid in it. I have used this on rocks with high caclium carbonate (CaCO3) content. Marble, travertine, petoskey stone etc. If you are cabbing I have had equal success with the Eastwing diamond wheel in 8000 grit from kingsleynorth.com/eastwind-diamond-fle-wheels.html#882=26748&883=26798 . I have polished with diamond Galaxy and Nova wheels down to 3000 but I had tried a discounted wheel which turned out to be eastwind and on some softer stones the 8000 grit belt on the eastwind wheel did a better job than a 8000 Nova. these would include the CaCO3 rocks and lapis
As far as SnO and Oxalic I use about 1/2# of SnO with 2 -3 tablespoons of Oxalic .
Post by Mel on Dec 6, 2023 8:32:21 GMT -5
Where do you get oxalic acid?
Currently I use my vibra-lap for polishing flats. I am looking for a flat spin on head for polishing on either a poly arbor or my Genie to hopefully speed up the process by using diamond paste or tin oxide though.
