wargrafix
Member since June 2023
Post by wargrafix on Dec 2, 2023 3:57:09 GMT -5
Been stuck in analysis paralysis. I have a 7 inch tile saw an want to move to a thinner continuous blade. Amazon has this, is it safe?
Post by RWA3006 on Dec 2, 2023 8:08:34 GMT -5
Should be safe enough however the cutting might go a little slower than you want because it uses fine abrasive to prevent the chipping of glass.
wargrafix
Post by wargrafix on Dec 2, 2023 8:44:34 GMT -5
Should be safe enough however the cutting might go a little slower than you want because it uses fine abrasive to prevent the chipping of glass. Slow and steady wins the race. Once its safe, i am good. I wait this long for rocks, I should be patient when cutting. Thank you very much!
