Post by countryfriedagate on Dec 9, 2023 19:04:09 GMT -5
Post by jasoninsd on Dec 9, 2023 23:03:35 GMT -5
I don't have a recommendation for a blade...I use a wet tile saw for my slabs... But! I will say those are some super cool corals!!
rockbrain
Member since January 2022
Post by rockbrain on Dec 10, 2023 10:25:06 GMT -5
Some great looking coral and a lot of cuts! Are you sure you're blade is "used up". As long as there is still a band around the outside edge there's life left in it. Have you sharpened it? It sounds weird but hitting the edge with a file can put it back in fine cutting shape. If the edge gets round it doesn't cut good. You need to square it again. Blade sharpening
Post by stefan on Dec 10, 2023 12:48:22 GMT -5
What size saw are you using? Water or oil? Feed type? 8 Gallons of cutting on my tile saw would be just about right for blade life, but that's because it spin faster, is hand fed, and uses water. 8 gallons of cutting on my 14" slab saw is just getting broken in, But it is a slower RPM, auto feed, and oil cooled. A $100 blade for the tile saw is really pushing it as the saw itself only cost $77. A $100 blade for the 14" would be the cheapest of the cheap (my current "cheap" blade was $120). Perspective is everything! Great cuts BTW, Really like those agatized corals, I have seen some pretty amazing ones, and man do the sparkle in the sun!
Post by countryfriedagate on Dec 11, 2023 18:07:33 GMT -5
Im using a Ryobi WS750L 7" Wet Tile saw, water cooled, sliding table, just something to get me started. Just got my wet stone polisher in, so ill be playing with that some this week.
