rockinronda
Member since December 2023
Post by rockinronda on Dec 14, 2023 12:10:54 GMT -5
I did a lot of don’ts, some on purpose, some from ignorance. Some trying to stay true to the Nat Geo way just to see what the outcome would be. I did separate the batch out that came with the kit and only tumbled half. I wanted a practice run that didn’t waste a lot of material and I put a cpl I thought were pretty as the carrot before the horse type thing. That was ignorant. I bruised and fractured a lot of it. I did not follow their timeline but I did max out each stage and reran my 1st stage to get rid of more blemishes. It did work but I lost a lot of volume. I did know to cherry pick the “dones” from the “not dones” but I only have this kit’s grits and have to see it through. The gem foam did put a basic shine on the rocks more than I thought it would. I have done a deep dive down the tumbling rabbit hole and learned a lot while this batch was in process. Though I’m hoping some of you will see what else I may be missing and educate me further, this is what I’ve learned so far. I do know that I need 2 sizes ceramic media (have lrg n sml coming, couldn’t find med/lrg combo)and at least AO polish. Tho I’ve seen comparison videos and Tin Oxide I think (personal opinion) it gives the absolute best polish. I do plan on getting a small amount for some super special rocks, but for me, economically it doesn’t make sense to use all the time. I don’t know how to tell a good AO from not so good AO. I do know the NG will be best for course grit stage as it tumbles too fast(that’s ok now I wanna vibro). Or maybe just more cushioning with media? Or maybe a mod/bigger wheel will turn more slowly? And has anyone tried going vertical with a rotary tumbler to turn other barrels using the same energy? I imagine on a grand scale-something like a carnival Ferris wheel 🎡 but the gondolas rotating by daisy chaining wheels and belts. I’m sure I’m missing something here, please fill me in.
Thanks for helping a new Tumbler out, Ronda
P.S. Is there a way to post pics on mobile version?
pebblesky
Member since September 2022
Post by pebblesky on Dec 14, 2023 13:04:38 GMT -5
IMO the rocks that came with Nat Geo aren't super beginner friendly. If I remembered correctly, they intentionally chose a colorful collection of rocks such as sodalite, aventurine, amethyst and some kind of jasper, agates and quartz. They don't have uniform Mohs scale, and some of them are challenging to tumble even for the non-beginners. Also, if you start with some less brittle rocks (by inspecting if there is too much crack when dry), the journey will be much more enjoyable.
And definitely fill the barrel 3/4 full, with a mixed variety of sizes. If the rocks came with the tumbler are not enough, you can always add small pebbles as fillers. I used to tumble red gravel pebbles and they are super easy to polish.
For posting pictures, I feel the easiest thing would be to upload the pictures to flickr and insert the image into the posts here.
rockinronda
Post by rockinronda on Dec 14, 2023 13:56:23 GMT -5
Yeah that’s why I tried to separate by hardness, like I left the tigers eye out cause I read that’s pretty soft. But I also purposely put a couple eye candy rocks in there, hardness be damned, because it’s my first run and I wanna see pretty rocks ^_^ Also, because my small knowledge base, I couldn’t positively identify each rock type and its hardness so there’s that as well.
Post by velodromed on Dec 14, 2023 15:56:05 GMT -5
One big issue is those 3 speed type tumblers rotate very fast, even on the lowest speed. As suggested by someone on here, I bought a cheap 7v power supply off Amazon and swapped it with the existing 12v on mine. It spins proper slow now and does a much better job. Other issues include poor quality grit/polish supplied with the machine, low quality/hard to tumble rock and the (crap) instructions. You came to the right place though, you’ll get all of the advice and recommendations to help you get going here.
rockinronda
Post by rockinronda on Dec 14, 2023 16:12:36 GMT -5
Yup that sums up what I was reading. While I’m pretty handy and not scared of much, I’ll admit I’m intimidated by messin with electrical stuff. Tho that does present as the best answer for rn. Thanks so much the both of you As far as grit, how do I tell a good quality one from a crappy one? I see references to mil size or something like that? I couldn’t find any measurable number in specs of grits I was looking at. Was that my first clue it was not a good one?
Post by velodromed on Dec 14, 2023 17:36:45 GMT -5
Yup that sums up what I was reading. While I’m pretty handy and not scared of much, I’ll admit I’m intimidated by messin with electrical stuff. Tho that does present as the best answer for rn. Thanks so much the both of you As far as grit, how do I tell a good quality one from a crappy one? I see references to mil size or something like that? I couldn’t find any measurable number in specs of grits I was looking at. Was that my first clue it was not a good one? It’s just plugging in a new power supply, super easy. Here’s the one I got. The source is the best way to tell. The Rock Shed and Kingsley north are very well know for quality grits. I’ve gone with 60/90 SiC (silicon carbide) for course in a small tumbler, and you’ll need much more of that then the others since it’s normal to run several or more course runs to get the rocks in shape. Then 180 or 220 for stage 2, which you’ll typically run just once, same with the rest of the stages. Then 500 or 600 for stage 3. Next 1000 AO (aluminum oxide) for pre polish and micron AO (10,000+) for polish. Those stores have great rough rock as well. Jaspers are real good learning rocks and there’s a bunch of different ones available. This is just my process I’ve spent the last 2 years figuring out and still have so much to learn. There are many roads that lead to a nicely polished rock. Takes some experimenting and lots of patience.
adam5
Member since August 2023
Post by adam5 on Dec 14, 2023 17:53:52 GMT -5
Yup that sums up what I was reading. While I’m pretty handy and not scared of much, I’ll admit I’m intimidated by messin with electrical stuff. Tho that does present as the best answer for rn. Thanks so much the both of you Here is the one I bought: www.amazon.com/gp/aw/d/B08LKRYFT6
rockinronda
Post by rockinronda on Dec 14, 2023 18:39:18 GMT -5
I have one of those! …Just don’t know if it has the variable feature or just different pin hole adaptors…and where did I last see it…🤔
Post by velodromed on Dec 14, 2023 18:47:36 GMT -5
I have one of those! …Just don’t know if it has the variable feature or just different pin hole adaptors…and where did I last see it…🤔 Yup! There’s a good chance you already have something that may work because it’s a fairly standard power supply for small electric things. If not, you can get them as low as eight or nine bucks.
Post by Jugglerguy on Dec 14, 2023 19:09:47 GMT -5
I made a video on how to use that tumbler that might help you out. I agree on the Rock Shed or Kingsley North for great grit at good prices.
Post by velodromed on Dec 14, 2023 20:02:33 GMT -5
I made a video on how to use that tumbler that might help you out. I agree on the Rock Shed or Kingsley North for great grit at good prices. Great video!! The first rock tumbling video I ever watched lol. Helped me immensely as so many of your other videos did. Many thanks Rob!
rockinronda
Post by rockinronda on Dec 14, 2023 20:59:40 GMT -5
That’s the Michigan Rocks guy! I watched so many videos and learned so much!
Post by jasoninsd on Dec 14, 2023 21:34:07 GMT -5
Not gonna lie...I read through "most" of the thread! LOL - I think there's two questions I didn't see answered. (If they were, I missed it! LOL)
Good quality grit = Grit from The Rock Shed. It's one of the most popular suppliers for grit on the forum.
Pics on "mobile" = Tapatalk. It's a free app that makes posting pictures from your phone super easy. I did pay for the "lifetime" membership as I post a ton of pictures...but the free version lets you post a limited number each month. It's definitely worth a try...
ctxtumblebug
Post by ctxtumblebug on Dec 15, 2023 1:54:42 GMT -5
I have a National Geographic tumbler that I use all of the time for tumbling nice rocks. I am very successful at doing this especially after watching MichiganRocks National Geographic tumbler tutorial video on YouTube. Here's a couple of my favorite rocks that were tumbled in a National Geographic tumbler.
rockinronda
Post by rockinronda on Dec 15, 2023 13:01:16 GMT -5
Thank so much everyone for all your help! 🥰
and smh I might’ve had a moment as I did not connect the dots between plug n play psu and hardwired psu 😣 was thinking get my dads old solderer out, yada yada yada.
A little star struck 🤩 Michigan Rocks Thank you so much for sharing your knowledge! You sir, are what led me down the rabbit hole, and I thank you for it 😄
Post by Jugglerguy on Dec 15, 2023 17:46:22 GMT -5
Thank so much everyone for all your help! 🥰 and smh I might’ve had a moment as I did not connect the dots between plug n play psu and hardwired psu 😣 was thinking get my dads old solderer out, yada yada yada. A little star struck 🤩 Michigan Rocks Thank you so much for sharing your knowledge! You sir, are what led me down the rabbit hole, and I thank you for it 😄 And this is where I learned everything, so you're in a good place!
rockinronda
Post by rockinronda on Dec 20, 2023 11:56:27 GMT -5
pebblesky
Post by pebblesky on Dec 20, 2023 12:09:57 GMT -5
These turn out nice! Keep rolling!
rockinronda
Post by rockinronda on Dec 20, 2023 12:36:19 GMT -5
Thank you! No moss gatherin on me I’m hooked!
Post by jasoninsd on Dec 20, 2023 17:35:02 GMT -5
Wow! That walnut didn't take much of a polish...but it held together nicely! Just kidding! LOL - Great job on your first tumble!!
