Post by broseph82 on Dec 30, 2023 16:07:58 GMT -5
Am I ever going to be able to find the blue band industrial for rocks ever again? Please don't say rockshed because Shaun doesn't know and doesn't even have the wait list anymore.... it's been years since covid and I still can't find one even used. Ugh!
chris1956
Member since July 2022
Member is Online
Post by chris1956 on Dec 30, 2023 16:22:40 GMT -5
You have probably checked this one also but just in case you haven't, try Minnesota Lapidary Supply.
dillonf
Hounding and tumbling
Member since February 2022
Post by dillonf on Dec 30, 2023 18:35:51 GMT -5
I feel your pain.
adam5
Member since August 2023
Post by adam5 on Dec 30, 2023 19:33:16 GMT -5
Given that the UV bowls are available, you could possibly pair a 10 lb bowl with the base from the Chicago Electric 18 lb vibratory tumbler. I do something similar with a UV minibowl and a RayTech TV-5 base.
Post by broseph82 on Jan 1, 2024 14:25:01 GMT -5
Given that the UV bowls are available, you could possibly pair a 10 lb bowl with the base from the Chicago Electric 18 lb vibratory tumbler. I do something similar with a UV minibowl and a RayTech TV-5 base. Thanks. I've seen online where someone used the UV-10 bowl with a raytech 10 base and worked really well.
