adam5
Member since August 2023
Post by adam5 on Jan 9, 2024 6:40:16 GMT -5
I have been happy with my tumblers, but it isn't the best setup for some tumbling experiments I want to do. So, I am in the process of building a multi-level tumbler. I got the top two levels running this morning:
I will post more about it once I have completed the work.
rockbrain
Member since January 2022
Post by rockbrain on Jan 9, 2024 10:12:47 GMT -5
Looks great! Looks like it's running smoothly.
chris1956
Member since July 2022
Member is Online
Post by chris1956 on Jan 9, 2024 10:26:10 GMT -5
Looks great!
Post by jasoninsd on Jan 9, 2024 21:57:16 GMT -5
That really looks fantastic Adam!! Great job!!
dillonf
Hounding and tumbling
Member since February 2022
Post by dillonf on Jan 9, 2024 22:05:48 GMT -5
Wow adam5 that looks great! Did you document your build? I'd love to read it. What size barrels you have spinning on there?
adam5
Post by adam5 on Jan 10, 2024 5:56:21 GMT -5
Thanks everybody! dillonf: I haven't documented the building process in pictures, but I do plan to write out a thorough description with photos of what I did and where I got the parts. The barrels on there at the moment are 3 lb barrels: 4 from my two CE tumblers, and 4 from wirejewelry.com. I will be doing more experiments with 3 lb barrels soon and need the additional barrels. My bigger barrels will be going on the lower levels.
pebblesky
Member since September 2022
Post by pebblesky on Jan 10, 2024 13:10:51 GMT -5
Wow!
dillonf
Post by dillonf on Jan 10, 2024 18:58:04 GMT -5
Thanks everybody! dillonf : I haven't documented the building process in pictures, but I do plan to write out a thorough description with photos of what I did and where I got the parts. The barrels on there at the moment are 3 lb barrels: 4 from my two CE tumblers, and 4 from wirejewelry.com. I will be doing more experiments with 3 lb barrels soon and need the additional barrels. My bigger barrels will be going on the lower levels. Awesome. Can't wait to check out your write up!
Post by liveoak on Jan 11, 2024 7:34:36 GMT -5
Looks great ! Patty
