storystones
Member since January 2024
Post by storystones on Jan 13, 2024 17:30:42 GMT -5
New to this forum - Intro: I make mixed medium sculptures using lapidary stone and various other materials. These creations have with them an associated short story that the sculpture represents.
I logged on here today because I have a specific question. I saw in a video made by Highland Park that in the final polish on their reciprocating flat laps they polish dry.
I have always used a wet cerium oxide slurry as the final polish. This stuff is very messy, dry would be great ! Does anyone polish dry and what polishing compounds are used. Any tips
Post by opalpyrexia on Jan 13, 2024 17:45:42 GMT -5
Welcome from Washington. Sorry, I can't help you with your flat lap slurry question.
Post by HankRocks on Jan 13, 2024 18:20:36 GMT -5
I run a Vibe Lap, 20 inch Lortone. Polishing cycle is run using Tin Oxide on a dedicated pan with tight weave Berber type carpet attached to bottom of the pan. It's always been wet slurry polish for me with just enough water to barely reach the top surface of the carpet. If the slurry gets too much above the carpet it get's messy. As it is the polished rocks do end up with polish stain on the sides. A good soaking in water followed by a good stiff bristle brush usually gets the residue off.
It seems to me that a polish slurry in the carpet would work better than a dry polish.
Henry
chris1956
Member since July 2022
Post by chris1956 on Jan 13, 2024 19:27:01 GMT -5
Welcome from Missouri.
New Player
Jan 13, 2024 20:59:13 GMT -5
via mobile
Post by Pat on Jan 13, 2024 20:59:13 GMT -5
Welcome from California.
I’d like to see your story stones, and read the story.
Post by vegasjames on Jan 14, 2024 0:22:47 GMT -5
Welcome from Southern Nevada.
Post by jasoninsd on Jan 14, 2024 10:20:21 GMT -5
Welcome to the forum from South Dakota! I don't use a flat lap...so can't give you an answer on that...but I did stay at a Holiday Inn Express last night...so if you have any other questions, I should be able to answer them!
rockbrain
Member since January 2022
Post by rockbrain on Jan 14, 2024 10:50:56 GMT -5
Welcome from Central California!
Post by liveoak on Jan 16, 2024 9:12:56 GMT -5
Welcome from NW Florida But I sure would like to see your sculptures Patty
