christianswest
Member since June 2023
Post by christianswest on Jan 14, 2024 17:27:17 GMT -5
Just got in from checking on my rotary tumblers and found frozen sludge. Tumblers were in the garage and inside the garage it got down to 16 degrees last night. Live and learn! After the barrels thaw out, I’m going to explore minimizing the sound and move them into my furnace room or insulating them outside using styrofoam coolers (I hate styrofoam!!) with some holes for ventilation, as I’ve seen people post before.
Post by jasoninsd on Jan 14, 2024 22:31:01 GMT -5
I used a cardboard box over my tumblers. Kept a thermometer under the box to makes sure the temp wasn't getting too high...it wasn't. Kept it warm enough under there to keep the rotaries from freezing.
christianswest
Post by christianswest on Jan 15, 2024 13:45:35 GMT -5
I used a cardboard box over my tumblers. Kept a thermometer under the box to makes sure the temp wasn't getting too high...it wasn't. Kept it warm enough under there to keep the rotaries from freezing. Thanks for that idea. Frozen slurry is very hard to get off the rocks. It finds every crack and divot and creates some of own divots in the rocks. I scrubbed all rocks with a soap and a brush, still was not happy and am running them in a borax bath. I had to discard some that got too eaten up. I never want to repeat this mistake! The cardboard box idea sounds good.
Post by parfive on Jan 15, 2024 13:57:39 GMT -5
Indoor/outdoor thermometer – stick one of the remotes in the enclosure. Memory will track high/low temp.
ThomasT
Trying to keep the dust down.
Member since June 2022
Post by ThomasT on Jan 15, 2024 14:02:47 GMT -5
Put some FDA approved or environmentally safe glycol antifreeze in there perhaps, and let her run...
dshanpnw
Member since December 2020
Post by dshanpnw on Jan 15, 2024 16:29:11 GMT -5
I think the cardboard box should work. I tried a box over mine once to minimize the noise and it got pretty warm in there. I would have tried putting a lot of water in the barrel and tumble them to get the solid slurry running again, or at least to make it easier to get off. Don't know if that would work.
geoff59
Member since October 2022
Post by geoff59 on Jan 22, 2024 13:09:53 GMT -5
Windshield washer fluid as the liquid? Although alcohol tends to dry out rubber…I am not sure what long term effects it might have on a rubber drum that always has liquid sloshing around inside.
