graysonig
Member since January 2024
Post by graysonig on Feb 2, 2024 22:12:45 GMT -5
Hi! New to tumbling a couple months ago. Found it by accident when I only meant to tumble one batch of stones for my nephews. Of course following included directions did not result in polished stones so found better instructions. Now I've gotten several rotary tumblers, a couple vibes and am looking forward to working on the fancy purchased stones I've gotten.
Next up will be a trim saw and flat lap I'm sure.
Enjoying reading and learning from this forum already.
Post by Pat on Feb 2, 2024 22:18:23 GMT -5
Welcome from California. Not a tumbler, but there are many excellent tumblers here.
Post by hummingbirdstones on Feb 2, 2024 22:21:37 GMT -5
Welcome from Northern Arizona! Check out Rob's ( Jugglerguy's) YouTube channel, Michigan Rocks, for excellent tumbling advice. Also the tumbling board here on the forum has enough information and advice in it that you could probably keep reading for a month straight and still not see it all.
graysonig
Post by graysonig on Feb 2, 2024 22:53:24 GMT -5
Welcome from Northern Arizona! Check out Rob's (jugglerguy's) YouTube channel, Michigan Rocks, for excellent tumbling advice. Also the tumbling board here on the forum has enough information and advice in it that you could probably keep reading for a month straight and still not see it all. Oh yes very familiar with Rob's channel. I use his lot-o method for my tv-5 and results are great. Just turned on my uv-18 tonight for the first time with some bigger rocks. Will see how that goes.
Post by jasoninsd on Feb 2, 2024 22:57:10 GMT -5
Welcome to the forum from South Dakota!
Post by Jugglerguy on Feb 2, 2024 23:17:55 GMT -5
Welcome to RTH!
Post by vegasjames on Feb 3, 2024 1:30:39 GMT -5
Welcome to the forum.
Post by rockjunquie on Feb 3, 2024 8:42:16 GMT -5
Welcome from Virginia!
zebra61
Post by zebra61 on Feb 3, 2024 11:24:53 GMT -5
Welcome aboard graysonig from Minnesota! The RTH Forum is a great repository for lapidary information and helpful hints from other enthusiasts! Mark
chris1956
Member since July 2022
Post by chris1956 on Feb 3, 2024 11:29:12 GMT -5
Welcome from Missouri.
graysonig
Post by graysonig on Feb 3, 2024 16:10:42 GMT -5
Thanks everyone.
Just today I started a load of Bahia agates. Certain this will be a many months long tumbling process. But having seen what the potential end result will be; I'm looking forward to it.
Post by opalpyrexia on Feb 3, 2024 21:29:01 GMT -5
Welcome from Washington.
dillonf
Hounding and tumbling
Member since February 2022
Post by dillonf on Feb 4, 2024 18:01:36 GMT -5
Welcome!
Post by liveoak on Feb 8, 2024 9:09:38 GMT -5
Welcome from NW Florida
Patty
rockbrain
Member since January 2022
Post by rockbrain on Feb 8, 2024 10:08:05 GMT -5
Welcome from Central California. Sounds like your addiction is accelerating at the normal pace.
geoff59
Member since October 2022
Post by geoff59 on Feb 8, 2024 20:25:37 GMT -5
Welcome from New Hampshire!
Post by drocknut on Feb 12, 2024 12:12:18 GMT -5
Welcome to the forum from south central Arizona
