wolverine
Member since October 2022
Post by wolverine on Feb 4, 2024 19:42:03 GMT -5
Post by jasoninsd on Feb 4, 2024 19:56:09 GMT -5
I love this idea!
Out of curiosity...what did you "learn" from the first batch?
wolverine
Post by wolverine on Feb 4, 2024 20:20:02 GMT -5
I love this idea! Out of curiosity...what did you "learn" from the first batch? This was my first time working with epoxy so learning the set up timing was one thing. I first poured a layer of colored epoxy then set the rocks on that then poured clear to cover the rocks and fill the molds. I placed the rocks on the first layer a little to soon so they settled into the epoxy instead of sitting on top. Not a huge deal but the rocks aren't seen as well in the side profile. Just needed a little more cure time on the first layer. Next is the amount of coloring to use to get the desired tint. A little color goes a LONG ways! Definitely need to start small with the amount of color used. Also the need to choose the correct rock to color combo to help make things stand out.
Post by jasoninsd on Feb 4, 2024 20:25:29 GMT -5
I love this idea! Out of curiosity...what did you "learn" from the first batch? This was my first time working with epoxy so learning the set up timing was one thing. I first poured a layer of colored epoxy then set the rocks on that then poured clear to cover the rocks and fill the molds. I placed the rocks on the first layer a little to soon so they settled into the epoxy instead of sitting on top. Not a huge deal but the rocks aren't seen as well in the side profile. Just needed a little more cure time on the first layer. Next is the amount of coloring to use to get the desired tint. A little color goes a LONG ways! Definitely need to start small with the amount of color used. Also the need to choose the correct rock to color combo to help make things stand out. Thanks for posting all this! I was wondering if you'd let us know...just so the "next person" could know the things to look for when doing a project like this. I really really really like the ones you did...but I can see how your "lessons learned" will make them even better!
dillonf
Hounding and tumbling
Member since February 2022
Post by dillonf on Feb 4, 2024 20:28:53 GMT -5
Very cool idea. Very creative. I like it!
