pebblesky
Member since September 2022
Post by pebblesky on Feb 6, 2024 1:03:42 GMT -5
Very interesting idea and the demo looks very promising. Looking forward to your progress.
gemfeller
Member since June 2011
Member is Online
Post by gemfeller on Feb 6, 2024 2:26:59 GMT -5
In gemology polariscopes are used mainly to determine whether gems are singly or doubly refractive. They are also used to determine optic character.
Basically they are largely used to distinguish between singly-refractive stones like red garnets and spinels and doubly-refractive gems like red ruby and other corundums as an example. (There are many double-refractive gems but fewer single that are cut as gems). The former transmit the same color in all orientations while the latter splits light into two or three directions (dichroismm or pleochroism) with the result tha different colors are visible when the gem is viewed in different orientations.
While useful in gem ID that determination is also critical for gem cutters and rough buyers. In cutting corundums (ruby and sapphire, for instance) the best color must be oriented so it shows through the top (crown) of the stone.
It's a lot more involved than that but it's late and I'm off to bed.
dillonf
Hounding and tumbling
Member since February 2022
Post by dillonf on Feb 6, 2024 6:51:01 GMT -5
My daughter got a "tracing box" as a present. It is a simple light box that you place a image on then put paper over the image to trace it. Not sure if it is powerful enough to do what you want, but it could be an affordable alternative. I'll see if I can find it - I haven't seen that thing around the house in a while.
Post by 1dave on Feb 17, 2024 15:08:10 GMT -5
Interesting ideas.
Post by 1dave on Mar 2, 2024 11:55:50 GMT -5
You are way beyond me.
iamchris
Member since June 2023
Post by iamchris on Apr 1, 2024 10:43:07 GMT -5
That's quite the LSA!
Sorry the new tools didn't result in the desired outcome, but I appreciate and admire your dedication to experimentation (and sharing your results with us!)
What are your plans for that big boy?
