ctxtumblebug
Member since August 2023
Post by ctxtumblebug on Feb 8, 2024 2:12:57 GMT -5
khara
Member since September 2022
Post by khara on Feb 8, 2024 6:37:13 GMT -5
Those look very nice. Also with these simple wraps, it allows the rock to really shine and be the star. Can you explain how you hold both the Dremel and also the cab to get the cut evenly around the perimeter?
Post by liveoak on Feb 8, 2024 7:16:29 GMT -5
They look really nice. I've done a couple of flat backed cabs like that, and cut the groove with my glass grinder, but, I'd agree, I'd like to know how you did such a good job on free-form tumbled rocks ? Or did you flatten the backs first ?
Patty
Post by rockjunquie on Feb 8, 2024 9:18:32 GMT -5
Nice and neat! Great job!
ctxtumblebug
Post by ctxtumblebug on Feb 8, 2024 12:43:44 GMT -5
Those look very nice. Also with these simple wraps, it allows the rock to really shine and be the star. Can you explain how you hold both the Dremel and also the cab to get the cut evenly around the perimeter? I just simply hold the dremel tool in my hand with my arm resting on a table for support. I take the rock and gently cut a small groove all the way around the rock with a beveled diamond tip by slowly guiding the rock along the cutting edge until I am satisfied with the results. To prevent cracking and chipping, I will dip the rock in water frequently throughout the process. This process does take some time for each piece but the end result is very satisfying. The wire wrap itself takes just a couple of minutes and the cutting takes about 5-10 minutes for each piece.
Post by susand24224 on Feb 8, 2024 16:40:40 GMT -5
You did an extraordinary job for your first attempts, or even for your 100th attempt! I am especially impressed that you accomplished this with very simple tools more manually than "usual." Nice!
Post by jasoninsd on Feb 10, 2024 8:51:36 GMT -5
ctxtumblebug - Fantastic job on those! I'm super impressed you cut the groove by hand with a Dremel!!
Post by Jugglerguy on Feb 10, 2024 9:08:56 GMT -5
I can’t imagine cutting a groove by hand with a Dremel. That’s impressive! I don’t deserve credit for teaching you this. You may have seen me do it first, but I follow Chuck’s ( Drummond Island Rocks) excellent tutorial. His method is different from yours, though. Chuck’s Groove Wrap Tutorial
