chase6806
Member since February 2024
Post by chase6806 on Feb 19, 2024 15:37:55 GMT -5
I’m not really into the hobbie. But do have some very large rhodnite I’d like to tumble. I’m talking softball football size and some smaller. I just thought it would be cool to have a couple large polished stones. They came from the sunnyside mine area in the SanJauns many years ago. I’ve done some reading and have an idea on how to go about it. Just wondering if anyone has ever tumbled something this large. I have a couple 55 gal plastic removable lid drums I was going to line with old conveyer belt with fins to aggregate to stones. I have some gear reduction setups and was going to build like a one time use wood frame. Anyone ever done something like this?
chase6806
Post by chase6806 on Feb 19, 2024 15:45:09 GMT -5
I also have a 15 gal plastic drum , but it might be harder for me to line the inside
whyofquartz
So, Africa is smaller than I expected...
Member since December 2019
Post by whyofquartz on Feb 25, 2024 12:10:49 GMT -5
there do exist 40 and 50lb tumblers, stuff that will probably handle basketball sized stones but my understanding is; as the rocks get bigger so do the grits, the tumble times and the number of stages. I know there are a few folks that run rigs that big but I don't recall who they are. there are guides on here for making your own barrels or relining barrels that might help you make your own giant tumbler
chase6806
Post by chase6806 on Feb 27, 2024 11:09:54 GMT -5
Thanks , I’ll try and search it .
chris1956
Member since July 2022
Member is Online
Post by chris1956 on Feb 28, 2024 19:53:40 GMT -5
Here is a link to a Michigan Rocks video on using a hand grinder to polish a large rock like @hefty mentioned.
Post by Bob on Feb 29, 2024 17:51:03 GMT -5
I'm tumbling quite a bit of it right now, lemon to apple size. And a few years back, I tumbled some pieces that were softball and slightly larger, though not as large as football.
What happened on the larger pieces is I got tired of grinding out cracks to make the rocks as perfect as possible. This has also happened with large pieces of lapis for me, though not near that large as that would be very expensive. But I've not been able to figure out if these cracks are in the rock to begin with, or some develop during tumbling, or both.
I have 40lb, 20lb, 12lb, and 6lb barrels.
Based upon my successes and failures with this material, these are my suggestions which are worth no more than you paid for them.
Take your smallest piece first, and only work it and save the rest to do only after you have developed experience and success. Tumble it with whatever- quartz, jaspers, agates, but not freshly broken ones with sharp edges. Also, I would attempt to have no other rock in the batch more than 1/2 the size of the rhod. Usually we spend a lot of time in coarse grind getting the imperfections out, and then only one week in the next finer grit which is often 220, then going finer each week after that. But with rhod, I've had best luck with going to 220 before the imperfections are all gone. I might have it in 220 for 2, 3 or even 4 or 5 weeks if that's what it takes to get it looking perfect. I also would tumble it in 220 only with other rocks that are well rounded and no more than 1/2 its size.
The dark manganese oxide part of rhod is frustrating especially if it is half the rock or more. It tends to damage in those places easily. The more pink the better.
Good luck, I think at least a year of tumbling experience with non-special material would be a good thing to do if you are new to tumbling.
wickedpebbles
Member since March 2024
Post by wickedpebbles on Mar 1, 2024 15:40:42 GMT -5
I wonder how well using tires to tumble big rocks might work out.
Post by Bob on Mar 4, 2024 14:44:20 GMT -5
I think there's a good reason why they never show the cleanout in these tire tumbler videos.
