Post by realrockhound on Feb 22, 2024 23:03:23 GMT -5
Anyone ever seen material like this? Its an aqua blue/green chalcedony.
Post by realrockhound on Feb 23, 2024 0:41:04 GMT -5
Maybe Mtorolite? Through my searches. I’m seeing similar
Post by Pat on Feb 23, 2024 0:59:53 GMT -5
Is there a fresh cut on it?
Post by realrockhound on Feb 23, 2024 1:04:27 GMT -5
Is there a fresh cut on it? Nope. Don’t want to cut it until I can identify what it is. It was stored in a bucket buried with a bunch of other nice stuff. Could be garbage, but have a feeling it might be something nice or rare.
Post by rmf on Feb 23, 2024 9:20:54 GMT -5
realrockhound My question is, the lighting is it correct? The top looks brownish, the bottom dark greenish with not a lot of translucence. most mtorolite I have seen has more translucence. If you draw a vertical line down from the tip of your thumb and a horizontal line from where the two curved conchoidal fractures meeet on the right. Where these two lines meet there is a spot that looks like green tree agate. The indian Green moss agate and green tree agate are part of the same material just different coloring within the same deposit. I am thinking this is some of that agate just with a slightly different mix of color. I am 100% sure maybe
chris1956
Member since July 2022
Post by chris1956 on Feb 23, 2024 9:52:21 GMT -5
I am pretty sure that is petrified pterodactyl puke.
Post by realrockhound on Feb 23, 2024 10:09:56 GMT -5
realrockhound My question is, the lighting is it correct? The top looks brownish, the bottom dark greenish with not a lot of translucence. most mtorolite I have seen has more translucence. If you draw a vertical line down from the tip of your thumb and a horizontal line from where the two curved conchoidal fractures meeet on the right. Where these two lines meet there is a spot that looks like green tree agate. The indian Green moss agate and green tree agate are part of the same material just different coloring within the same deposit. I am thinking this is some of that agate just with a slightly different mix of color. I am 100% sure maybe Lightning is not correct. It’s distorting the color. I’ll take more pics
Post by realrockhound on Feb 23, 2024 11:31:39 GMT -5
I’ll nut up and take a slab off the back. I could be Indian green moss agate, but from everything I have of that material this doesn’t seem the same (not saying it isn’t, just still have my suspicions from examining with a light, etc..) we’ll get an answer.
gemfeller
Member since June 2011
Post by gemfeller on Feb 23, 2024 12:52:59 GMT -5
Maybe Mtorolite? Through my searches. I’m seeing similar Mtorolite is chrome chalcedony. Use a Chelsea filter to see if there's any red hue in light transmitted through the stone. That would confirm the presence of chroium.
Post by MsAli on Feb 23, 2024 13:13:42 GMT -5
Hard to tell but it does look like there is a white spot w/ green in it
I'd just cut a slab off
Post by realrockhound on Feb 23, 2024 13:59:09 GMT -5
Hard to tell but it does look like there is a white spot w/ green in it I'd just cut a slab off I’ll do it that tomorrow see what it turns out. On the thinner edges I was able to shine a light through. It has transparency. It has a name written on it with sharpie that has faded out. It starts with a “C” but fades off and I can’t quite make out the writing.
Post by Rockoonz on Feb 23, 2024 14:12:49 GMT -5
I'll name him George.
Post by MsAli on Feb 23, 2024 15:07:56 GMT -5
I think you said the magic words starts with a "c" . Green Chalcedony will sometimes for lack of a better description areas of white areas.
Post by realrockhound on Feb 23, 2024 16:21:22 GMT -5
I think you said the magic words starts with a "c" . Green Chalcedony will sometimes for lack of a better description areas of white areas. So you’re saying it’s more than likely just some crappy green agate? To the junk pile it goes 😂
pebblesky
Member since September 2022
Post by pebblesky on Feb 23, 2024 16:35:33 GMT -5
How can green agates be crappy😂
Post by realrockhound on Feb 23, 2024 16:38:41 GMT -5
How can green agates be crappy😂 If it’s a dime a dozen, or has no special qualities to it, I don’t even want to look at it. As I’ve been labeled by jasoninsd “a bonafide rock snob” 😂
Mark K
Member since April 2012
Post by Mark K on Feb 23, 2024 19:38:15 GMT -5
Hit the writing with your UV, a strong light from multiple angles and a weak light same. Try with both room lights on and off
Post by MsAli on Feb 23, 2024 19:53:59 GMT -5
Oh I don't think it's junk at all. Wait til you cut it
Post by amygdule on Feb 23, 2024 20:04:21 GMT -5
A thin slice of Green Chalcedony from the Oregon Coast...
Post by realrockhound on Feb 23, 2024 20:08:34 GMT -5
I'm cutting this crap as we speak. We will have answers. I could make out "CAN" almost looks like it says canal maybe. No clue
