jeg
Member since January 2024
Post by jeg on Feb 28, 2024 8:20:45 GMT -5
Hi I am new to tumbling using a loritone 33b trying to finish my first batch of mixed calcite can seem to get a good shine with al oxide any thoughts on what i can try . thank jerry
rocknewb101
Member since October 2022
Post by rocknewb101 on Feb 28, 2024 9:21:35 GMT -5
Hi jeg - where did you get your polish from? I've never tumbled calcite, but I understand it's quite soft (3 mohs, if I'm seeing correctly). IMO this makes it hard to tumble - make sure you are adding in a ton of ceramic or plastic media to help cushion it. Also, if you're able to share pictures that'll help folks see what is going on - possible bruising. Lastly, what stages are you using with your grit? Typical is 60/90, 120/220, 500 (or 600) and then AO polish, which if you got from somewhere like rockshed/kingsley north should be upwards of 8000. Amazon polishes typically don't go this high (1200 usually). With ALL of this being said - I'm not at all familiar with calcite and super soft stones, so someone may come along and totally correct what I've said specifically thinking you don't need t start with the 60/90 as it's likely too coarse??
dshanpnw
Member since December 2020
Post by dshanpnw on Feb 28, 2024 10:21:57 GMT -5
Hello Jeg, rocknewb101 is correct, calcite might not be the best rock to tumble especially for the very first batch because it is super soft. Did your rocks get a lot smaller after the first two stages? Did they loose a lot of mass? Calcite would probably grind away very fast. I'd be anxious to see photos no matter how they turn out for you. I've never tumbled calcite either, but I'm thinking it would be a lot like tumbling Petoskey stones where you'll need to "dry" polish them using ground up corn cob.
jeg
Post by jeg on Feb 28, 2024 10:25:17 GMT -5
i was using al oxide from kinsley
Post by Fossilman on Feb 28, 2024 11:28:53 GMT -5
Might have to use cerium oxide. The Rock Shed out of South Dakota has the best grits and powders, fast service too..
jeg
Post by jeg on Feb 28, 2024 12:08:42 GMT -5
thanks i have some cerium
Post by velodromed on Feb 28, 2024 16:04:33 GMT -5
I have some SiC grit I can send and rock shed AO, prepolish (1000) and polish (sub micron size or something). The rocks I’m sending are all jaspers, cherts and agates (round 7 mohs scale), so will need multiple course stages for shaping. I like to use ceramics in the pre polish and polish stages to help avoid bruising. I’ve extra so will include some.
dillonf
Hounding and tumbling
Member since February 2022
Post by dillonf on Feb 28, 2024 21:32:59 GMT -5
chris1956
Member since July 2022
Post by chris1956 on Feb 28, 2024 21:44:48 GMT -5
Thanks for posting this Dillon. I knew about the dry method for Petoskey stones but haven't seen the wet procedure before although I have heard of it. I am going to have to try some and see what happens.
