Mark K
Member since April 2012
Post by Mark K on Mar 18, 2024 20:14:10 GMT -5
What do you call the part that connects a diamond grinding disc to the end of a motor shaft? This is driving me up the wall and I need to make a bigger grinder for my projects.
realrockhound
Member since June 2020
Member is Online
Post by realrockhound on Mar 18, 2024 20:27:26 GMT -5
I was gonna say the “taint” until I saw the rest of this post.
Are you talking about the lock nut?
Mark K
Post by Mark K on Mar 18, 2024 20:42:12 GMT -5
No, I bought a 7 inch grinding disc and it does not fit on my giant angle grinder because I took the nut and other part off to allow the 4 inch one that had its own threads to go on. Now, a few years later, I have no idea where the old parts are and the grinder is a true antique. So, I figure I will mount the disc on a motor, but I can not figure out what to call the part that the disc goes onto that mounts on the shaft. I may just have to buy a brand new angle grinder and go from there, but don't really want to.
chris1956
Member since July 2022
Post by chris1956 on Mar 18, 2024 20:48:41 GMT -5
Chuck?
realrockhound
Member is Online
Post by realrockhound on Mar 18, 2024 20:59:28 GMT -5
No, I bought a 7 inch grinding disc and it does not fit on my giant angle grinder because I took the nut and other part off to allow the 4 inch one that had its own threads to go on. Now, a few years later, I have no idea where the old parts are and the grinder is a true antique. So, I figure I will mount the disc on a motor, but I can not figure out what to call the part that the disc goes onto that mounts on the shaft. I may just have to buy a brand new angle grinder and go from there, but don't really want to. I think I know what you’re talking about. Post a pic. Someone will nail it. I don’t think you’ll need to buy new.
Mark K
Post by Mark K on Mar 18, 2024 21:35:31 GMT -5
I can't post a pic because I don't know what it is called to look it up.
Paradox
realrockhound
Member is Online
Post by realrockhound on Mar 18, 2024 21:39:55 GMT -5
I can't post a pic because I don't know what it is called to look it up. Paradox The spindle?
oregon
gem lap trim saw
Member since August 2015
Member is Online
Post by oregon on Mar 18, 2024 21:53:02 GMT -5
Post by parfive on Mar 18, 2024 22:03:09 GMT -5
I can't post a pic because I don't know what it is called to look it up. Paradox Ever heard of Google? Or QuackQuackGo? Makita calls it an inner flange. Milwaukee, just a plain ol’ flange. makita.in/wp-content/uploads/2020/11/GA4050R_PD.pdfPlenty more where that one came from.
Mark K
Post by Mark K on Mar 18, 2024 22:39:47 GMT -5
I can't post a pic because I don't know what it is called to look it up. Paradox Ever heard of Google? Or QuackQuackGo? Makita calls it an inner flange. Milwaukee, just a plain ol’ flange. makita.in/wp-content/uploads/2020/11/GA4050R_PD.pdfPlenty more where that one came from. Of course I have heard of google. I can't google something that I can't name. I couldn't think of that part's name either. It isn't the part I meant, but it is also helpful.
realrockhound
Member is Online
Post by realrockhound on Mar 18, 2024 22:56:40 GMT -5
If it isn’t the spindle, then I’m completely at a loss. Only thing to do is try to identify it through a parts catalogue. Best of luck
dillonf
Hounding and tumbling
Member since February 2022
Post by dillonf on Mar 18, 2024 23:34:12 GMT -5
I've heard them referred to as "adaptors" before. Doesn't seem like that is what a supplier will call it though.
Mark K
Post by Mark K on Mar 19, 2024 5:11:56 GMT -5
Dillon figured it out.
Spindle adapter.
I think I am going to go with a different route after looking at them though.
chris1956
Post by chris1956 on Mar 19, 2024 12:16:10 GMT -5
Alright.
Post by Rockoonz on Mar 19, 2024 13:05:02 GMT -5
If threaded discs fit your machine the standard 5/8" coarse thread will as well. When I had a similar thing happen with my old genuine metal 7" grinder the nut from a 4 1/2" grinder that died fit just like the original.
Mark K
Post by Mark K on Mar 19, 2024 14:42:00 GMT -5
That may be an idea too.
Mark K
Post by Mark K on Mar 19, 2024 16:20:05 GMT -5
That was a good idea. I borrowed the parts off of the smaller one I have and put the big one together. I did two preforms in less than the time it took to out the tool together. It is really windy here right now so the dust blew away at a rapid pace. Didn't even smell it except for the one time the wind died for a few seconds. On the second sphere, I thought I was half way done and it turned out that I was completely done. I should have taken a video.
Mark K
Post by Mark K on Mar 19, 2024 16:35:17 GMT -5
I made a video. It will be a new topic.
