Post by 1dave on Mar 21, 2024 9:58:24 GMT -5
Acanthite = Silver Sulfide. It is black and heavy. as crystals: As layers: Stream worn:
Post by vegasjames on Mar 21, 2024 13:28:00 GMT -5
Just went back to the mine last week and dug out a lot more. Found a couple nice veins of it in the mine.
titaniumkid
Member since June 2023
Member is Online
Post by titaniumkid on Mar 21, 2024 16:00:02 GMT -5
I have a rock from Broken Hill (NSW, Aus) that looks similar to the second image (layers). There is a fragile layer of crystals that are dark up close. I thought it may have been galena but maybe it's not. The region has lead, zinc, and silver deposits.
Post by vegasjames on Mar 21, 2024 21:36:22 GMT -5
I have a rock from Broken Hill (NSW, Aus) that looks similar to the second image (layers). There is a fragile layer of crystals that are dark up close. I thought it may have been galena but maybe it's not. The region has lead, zinc, and silver deposits. Acanthite and galena can occur together and they have very close to the same densities. Since your rock is not a pure mineral, density testing is out anyway. Chemical testing would be your best bet.
For example, hydrochloric acid is pretty easy to obtain. Crush a small piece of ore and try dissolving the powder in the hydrochloric acid. Filter off the solution and expose to sunlight. Silver chloride will turn purple in the sunlight.
If you have access to nitric acid, even better. This can form silver nitrate with silver and lead nitrate with lead. Silver nitrate will turn black in sunlight. Adding some sodium chloride ("table salt") to lead nitrate solution will form a white precipitate of lead chloride.
titaniumkid
Member is Online
Post by titaniumkid on Mar 21, 2024 22:27:02 GMT -5
