Post by Son Of Beach on Mar 22, 2024 21:34:28 GMT -5
Brainstorming something here...usually I'm off the mark anyhow.
Is there an epoxy or glue or sealant that would hold up to some abuse in the tumbler?
It wouldn't have to be more than a week or two at a time, something I could reapply as needed.
Trying to think of a way to keep botryoidals, quartz crystal faces, druzy pockets, that sort of thing.
Maybe something that would come off with heat or another chemical reaction?
I'm really fishing here lol
pebblesky
Member since September 2022
Member is Online
Post by pebblesky on Mar 22, 2024 21:46:54 GMT -5
I have heard that applying a thick layer of hot glue to the surface will be enough to keep the surface intact. I haven't tried that myself yet.
Post by parfive on Mar 22, 2024 21:48:20 GMT -5
People have used wax. I’d try the most epic of hard dop waxes.
chaosdsm
Member since April 2024
Post by chaosdsm on Apr 20, 2024 11:52:32 GMT -5
In answer to the thread title: No... and yes.... there's no epoxy as hard as the type of rocks that would normally be tumbled. The hardest epoxies are around 88D - 90D Durometer, which is about the same as bone, which is about 4.5 - 5 on the Mohs scale. Also the ones that get that hard are "usually" more brittle than Silicon Carbide grit.
FROM CHEMTRONICS: BUT, just about everyone that makes epoxy will say the same thing.
NOW.... if you want to encapsulate a pocket or something to protect it but still show it off, you can use epoxy for that. There are some "crystal clear" epoxies that are very hard and as clear as acrylic, some even have UV stabilizers in them to help resist yellowing.
Otherwise, as parfive said "dop wax"
khara
Post by khara on Apr 20, 2024 16:46:49 GMT -5
Hope you do some tests and report back. It would be cool to protect druzy areas in a tumble.
Post by manofglass on Apr 21, 2024 13:46:18 GMT -5
